upgrade
35 TopicsWAX620 upgrade to 11.8.0.10 reset vlan
Last night I upgraded the firmware on my WAX620 from 10.8.13.2 to 11.8.0.10. Everything went fine except for one thing, the main SSID was configured to use vlan111 and this upgrade process reset it to use vlan1. Since my network was not configured to use vlan1, all traffic was blocked causing it to appear as though the upgrade failed. To fix, I brought up vlan1 on the interface so it could reach the internet and more importantly Insight. Next, I logged into Insight and changed the configuration to use vlan111 as it was originally configured. Hopefully this is just a one-off issue. Wanted to report it in case someone else runs into it.Solved324Views0likes2CommentsHow to Upgrade the CPU and RAM in a ReadyNAS 516
Well I have done it. It seems to be working great. I've ran a few basic tests and you really don't get a idea of the differance without accessing it. you can notice the speed Improvment. Accessing files is much snappyer. The main reason for the Upgrade is more Transcoding capabilities at once uisng PLEX which is installed on it. The Upgrade went easyier then I thought it would. I have lots of pictures to help people out that also want to try this. My RN51500 ReadyNAS I actually got about 6 months ago USED for about half the price of a new one. I got it from a 3rd party seller on Amazon. They did screw up at first and sent me a ReadyData 516. That was worthless to me as it wouldn't allow me to use my HDD's I already had. You can only use one's you get from Netgear with a ReadyData!!! They look the same, they are NOT the same!!! This full upgrade cost me around $300 to do, to bascially make is a ReadyNAS 716. Other then the 10Gigbit port. So onto the show. This will be pretty LONG. Before you start, make sure you BACKUP your NAS. You do have a real Backup right? The Orignal CPU is a i3-3220. The NEW CPU is a E3-1265 V2. This is the exact CPU used in the ReadyNAS 716. So for PLEX transcoding, Very roughly speaking, for a single full-transcode of a video, the following PassMark scores are a good guideline for a requirement: 1080p/10Mbps: 2000 PassMark & 720p/4Mbps: 1500 PassMark. The listing on Amazon for the RN51600 CPU is currantly WRONG. It shows a i3-2120. It's NOT! Netgear lists the correct CPU and pulling my old one shows the correct one also. Here is my ReadyNAS 516 in my small closet that's about in the middle of my house where I keep my Network stuff. There's also a duel fan setup above the door that's temp controlled. It auto runs and stops as needed. The fans are quite and mounted to a wood type vent, which I painted to match the rest of the hall way with the vents going in a up direction. Cool air gets sucked in from the bottom of the door where there's about a 1" gap, and gets blown out the top into the hallway. Currantly there's a APC UPS Pro 500, a Motorola Cable Modem, a Asus Wifi Router. The FREE one form T-Mobile!!! Under that is a ZyXEL GS1910-24 Managed 24-port Gigabit Switch. Both 1 gigabit ports on the NAS as plugged in and Bonded. That's the 2 yellow cables plugged in on the left side of the switch. There's also a Tivo Stream Box there on the right of the switch for my Tivo Roamio OTA. My house I wired up and have Multi-Keystones in al my rooms. I'm using Cat-6 cables from Monoprice. Here is the main things you need. The CPU, which is a E3-1265L V2. This is the same one used in the 716. I got this one from ebay with a buy now price of $275. I made a offer for $200 and he countered with $225. So that is what I paid for the CPU. Pay attention to what you are bidding on!!! There's E3-1265L that you can buy for under $200, but it's not a V2 or a chip that was sold in the marketplace. They are engineering samples whch are not suppose to be sold. You see they're all coming from China! You are talking your chances. The Memory I got from Amazon for $84.99. It's Crucial 16GM Kit. This is Unbuffered ECC UDIMM Server Memory. It's 1.3 Volts. DDR3 at 1600 MHz. This is a closeup Here is a closeup of my new/used CPU I got on ebay for $225. Inten XEON E3-1265L V2 You also need some Thermal Compound Paste for between the CPU and the Cooler. This is Arctic Silver 5 that I got from Amazon. There's enough here to do a whole lot of CPU's!!! It's made of 99.9% pure silver and is not electrically conductive. But this or anyting else can cause issues if you use to much as gets all over everything. This was $7.39 at Amazon. This is used to clean the Heatsink and can also be used to clean the old CPU. You don't want any of the old stuff left on. This works great to clean the junk off. There's also enough to do many CPU's and heatsinks. This was $8.11 on Amazon. Once you have the CPU, the RAM, The Thermal Compound and cleaner, we can start the Upgrade Process. This is my NAS now pulled out of the closet and on the table. You can see I like the label things. My HDD each have a label on it, and because you can't just pull them to look, I also have a label on the side of the case. What kind and size of HDD and when it was Installed. I didn't pop them all in at one. I Installed a HDD as I needed them for less wear and tear. Hopefully doing this I won't have a issue of 2 HD taking a dump at once. The first 4 HDD are WD Red 3TB is size. They were in my ReadyNas NV+ V2 before I got this NAS. The first one installed was on Jan 17th 2013. So it's coming up on almost 4 years now. Here's a closeup of my first NAS HDD almost 4 years ago now. I pulled all my HDD's. You don't have to, but it makes the NAS much lighter to move around and take apart. As they are all labeled, they all will easily go back in where then need to be. Remove the 7 screws on the back of the NAS at the red circles. I learned there was 1 broken off screw o the bottom right. I didn't know that. Not sure why that is? Who wanted to take it a part for whatever reason. Once the 7 screws are removed. You want to slide the cover back about half a inch and then lift up. There is a lip on the top front of the cover and lips on both bottom sides. It's a little snug. I used the flat edge of the screwdriver and sticking it inbetween the bottom bolt locations, carfully pried just a little be on both sides, then pulled back and up and off. This is a right side view of the NAS. You can see the Hard drive slots on the left and the motherboard there on the right/back in this picture. Now you have 2 screws to remove. You see them here in the picture at the red circles. Once Removed the back will pull off. See next picture. You can go ahead and carfully pull off, top off and down carfully where you can reach in and unplug the power connection and the fan connection as shown in the red circles. Here is what it looks like once you remove the back of the case. You can see the HDD board and the motherboard is there on the right. The red circles are the 2 connection points that link the 2 boards togeather. You want to make sure they plug in togeather when you re-Install the motherboard, which does have alignment pins on the motherboard case cover to help you. This is the left side of the NAS. The motherboard side. Remove the 4 screws that are in the red circles. Once done, you can carfully pull this out, starting with the top. There are wired connections on the bottom, watch out, Tilt down from the top, swinging down most of the way where you can reach the wire plugs. Here I am swinging the motherboard down where I can then get access to the wired plugs. Here's a close up. There are 5 different plug connections. One I have removed already. They all only go in one way, except the small 2 wire plug. I just plugged it back in the same way it came out. A couple are locked in and so you need to push t unlock and pull. That's 2 of them, the one I already removed and that large one that has P1 on it. The thers just pull off. Be careful and kind of wiggle off. Here is what the NAS looks like once the motherboard is removed.Upgrading firmware on ReadyNAS 3200
I have inherited an old ReadyNAS 3200 with firmware version 4.2.22. I want to upgrade it to the newest firmware 4.2.31 but am unsure if there is a step process or if I can just load 4.2.31. This is part of a production network and am unsure about how long this might take to upgrade. The system is also over 80% filled. Any help with this would be appreciated. Thanks.PSU not detected after upgrade to FW 6.9.1
After upgrading to FW version 6.9.1 from 6.8.x i see log messages that indicate PSU1 not detected and PSU2 not detected. The unit is populated with 12 4TB drives. I've attempted to upload the logs but the zip file is not accepted. Furthermore only jpg,gif,png,pdf are the only file types accepted. Am I expected to convert every file contained log download from .log (text) to a pdf?Solved5.6KViews0likes13CommentsReboot ALWAYS fails after firmware upgrade on ReadyNAS RR4312X
Hi, I've just upgraded our NetGear ReadyNAS RR4312X from 6.8.0 to 6.9.1 and actioned a reboot using the webUI after the upgrade. However once again (this happens after every FW upgrade), the system fails to come online again. The system doesn't even respond to PINGs. - We have to power cycle the system after every upgrade to get it back online again. NB: The firmware installs successfully everytime, so it's just the reboots afterwards that are problematic. Not good for remote sites! Any idea's please? P.S. my entered text 'ReadyNAS RR4312X wont save in the 'Model' section of this web support form.2KViews0likes7CommentsAfter update of 516 from 6.6.1 to 6.8.1 old volumes from prior factory default showed back up
I just upgraded from 6.6.1 to 6.8.1 (after testing 6.8.1 on a 316). The upgrade process went smootly and it seems to work okay, however, some old volumes (vol2 and vol3) that were from a prior factory default showed back up in the UI. Under system --> volumes it now shows data, eda1 (expected), but also shows vol2 and vol3 (that should not exist). The volumes vol2 and vol3 do not show that they are using any disks and the only option I have is to destroy or balance them (balance is strange as there are no disks assigned). I would like to destroy them, but I am a little nervous and want to check with someone from Netgear before doing so as I dont want to inadvertantly destroy data or eda1 volumes. Thanks in advance, -David857Views0likes2CommentsShares goes read-only after a while after upgrade to 6.8.0
Hi, After upgrading to 6.8.0 I have a strange behavior. After every boot, everything is fine for some time (up to half an hour) and then file system goes read only. After boot: root@NasSebUltra6:/# mount | grep -v snapshot | grep '(ro' tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) After some time: root@NasSebUltra6:/# mount | grep -v snapshot | grep '(ro' tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) /dev/md127 on /data type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=5,subvol=/) /dev/md127 on /home type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=256,subvol=/home) /dev/md127 on /apps type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=257,subvol=/.apps) /dev/md127 on /run/nfs4/home type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=256,subvol=/home) Strange thing is, there no new entry in system logs. It juste goes in readonly until next reboot. I launched a scrub just in case, but I don't really believe it will chance anything. Does anyone have some idea about how to solve this ?Solved1.8KViews0likes3CommentsProSafe Firewall FVS336Gv3 firmware upgrade question
Hi all, I have a quick question regarding upgrading the firmware on a FVS336Gv3. It is currently running on 4.3.3-8 and I want to upgrade it to the latest 4.3.5-3, will the settings already in the device be retained or will they get wiped from the firmware upgrade? Thanks.3.4KViews0likes2Comments
