tcander
Apr 14, 2018Aspirant
Can't get Orbi to work with Circle
I have Android 8.1.0 and I can't get Orbi to work with Circle. I open Circle app and click "Get Started". It says make sure you are connected to your router, which I am. So I click Next. Then it says that your firmware is out of date (which it is not!!!!). So it asks if I would like to update the firmware and gives to choices to the question:
Yes Please or No Thanks. If I choose no thanks, it stops the whole thing as if I did not want circle at all. If I choose "Yes Please", it gives me a login prompt for my router credentials, which I put in.
Then it says "Updating Firmware .... take a break this will take a few minutes".
After a long time, it then says: "Reconnect to your router .. Return to the Wi-Fi settins on this Android device and connect back to <myssid>. When you return here, we'll enable circle on your router. " But I am already on the orbi's ssid. So then I click Next.
Then it says "Enabling Circle .... This will just take a moment.
Then it says the same thing as before "Reconnect to your router .. Return to the Wi-Fi settins on this Android device and connect back to <myssid>. When you return here, we'll enable circle on your router. " The "Next" button replaced with a non-clickable button that says "Logging In ..."
It stays there the rest of the time.
What is wrong?
What FW version are you using?
Try setting up Circle on the router first with a PC and a web browser connected to the routers web page.
- tcanderAspirant
My firmware version is:
V2.0.1.4
model rbk50
I do not see any way of setting up circle via the web interface.
how do I do it that way?
