DorkiOrbiFW's avatar
DorkiOrbiFW
Apprentice
Jan 25, 2019
FIX - Orbi Firmware 2.2.1.210 Performance Issues
Hello Orbi Community,
If any of you are struggling with performance issues with your Orbi system that is currently running on FW version 2.2.1.210, you are not the only one. Countless amount of people have complained to Netgear about this issue and nothing has been done to resolve this. I looked through a ton of threads and it took me some time to put all kinds of codes together to block Orbi from auto-updating to FW version 2.2.1.210 after rolling it back to version 2.1.4.6.
So, without further ado, here's the solution:
  1. Enable telnet on each Orbi (Router and/or Satellite)
    • This can be accomplished by putting ip_address_orbi.debug.htm
    • EX: 192.168.1.20.debug.htm
  2. Telnet into each Orbi and/or Satellite
    1. For macOS, seek this link for assiatnce to get Telnet capabilities:
    2. For Windows, install a trusted program called PuTTY.
      • You'll see the telnet option.
  3. For each Orbi (Router and/or Satellite), you will need to do the following when telnetting into the unit:
    1. Input your username and password
      • Username: admin
      • Password: Same password you use to login to Orbi's dashboard
    2. Once you're successfully logged in, enter the following codes EXACTLY as listed.
      • nvram set orbi_auto_upgrade=0
      • nvram set auto_check_for_upgrade=0
      • nvram set auto_update=0
      • nvram set orbi_auto_upg=0
      • nvram set orbi_auto_flag=0
      • nvram commit
        • If you forget to put any of these lines of code, your Orbi will fight you and auto-update to the 2.2.1.210 FW.
    3. End the telnet session
    4. Repeat this process until you have done this to every single Orbi unit you have in your network.
  4. Manually update the firmware on each Orbi unit
    1. Enter the IP address of each Orbi into your web browser
    2. Select "Firmware Update"
    3. Upload the 2.1.4.6 firmware
    4. When prompted with a message stating your uploading an older firmware, hit yes.
    5. Allow the Orbi to downgrade to the 2.1.4.6 firmware
    6. Repeat process for all Orbi units
  5. ENJOY A STABLE VERSION!
Hope this helps Orbi users near and far until Netgear can release a good, solid and stable firmware.
Take care! 😊
