user_error's avatar
May 16, 2019
Internet Connection Drops - Re-Enabled by Testing or Renewing Ip
Hey All - I get disconnected from the internet (sometimes multiple times) daily and have noticed that if go to Home > Internet > Test OR Advanced Home > Connection Status > Renew, I will generally get internet connection back almost immediately. I always stay connected to WiFi and will even refresh the Router home pages a few times to see if it tells me I'm not getting an IP (Frontier), but the IP (and status page) are good, yet no internet unless I do one of the above.
I've had this problem for a while now and kept hoping that FW updates were going to resolve it, but have seen at least three updates and the problem persists. As you other 'Home Network Customer Service Managers' (aka dads or moms) know, I get to hear all the family member's complaints every time this happens and how our internet sucks. I've been babysitting this thing long enough and am ready to either find the root cause or roll back to my previous router.
Thanks in advance for your assistance!
V2.3.1.60
What is the Mfr and model# of the ISP modem the router is connected too?
zyxel hla 3000 (Frontier FiOS)
Is the Orbi system operating in Router or AP mode?
router
How many satellites do you have?
1
3100
What is the distance between the router and satellite(s)?
approx 40' - 50'
What channels are you using?
2.4 = tried 1, 2, 3 and 5 = 48
Any Wifi Neighbors near by?
currently see 2 others, but think that can be up to 5?
  • plemans's avatar
    The zyxel HLA3000  is (i believe, I don't have one) and ethernet coax bridge device. What router/modem is connected to the other end of it?
    • ekhalil's avatar
      ekhalil
      Master
      Please try reducing the lease request time and see if that will give you an improvement:
      • From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
      • Enter admin as user name and your router’s management password
      • Tick "Enable Telnet" option
      • Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
      • Enter the following commands:
        • root@RBR50:/# config get wan_lease    — Should give you --> 86400which means 24 hours
        • root@RBR50:/# config set wan_lease=1800
        • root@RBR50:/# config commit
      • user_error's avatar
        user_error
        Tutor
        Thank you - I've set the config per your recommendation and will post an update later.
      user_error
      Tutor
      Thanks for the reply - that zyxel hardware is connected via coax to an ONT (Optical Network Terminal?) which appears to be an Arris ONT1000-PS1-2G-SFU, Rev A, FW Rev B.
  • FURRYe38's avatar
    V2.3.1.60
    Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
    I presume no built in router with this unit?
    Swap out LAN cable between the FIOS unit and RBR?
    router
    1
    3100
    approx 40' - 50'
    Channels 1, 6 and 11 are only recommended channels to use on 2.4Ghz.
    Does both wireless and wired connection loose access to the internet when this happens?
    • Ghost71's avatar
      Ghost71
      Guide
      I thought I would provide an update on my issues (frequent internet disconnection that forced me to "release/renew" in order to re-establish service).
      We recently moved into a new home, 1 mile away from our old one.  Same ISP (Frontier), same ORBI equipment.  The problem is now solved.  It appeared to be the ONT in the old house that was outdated and needed to be replaced.  The new Frontier install came with the latest equipment in the garage and what's more, the tech stated that he was familiar with the issue at that he had heard the complaint before, and replacing the ONT solved the issue.
      So there you have it.  We've been in the new house now for about 10 days and not one disconnect.  In the old house, I'd have had 2 or 3 a day.
      I hope this helps.
      • FURRYe38's avatar
        Glad they were able to figure it out. Thanks for letting us know the experiences.
        I hope this helps.
    V2.3.1.60
    router
    1
    3100
    approx 40' - 50'
    currently see 2 others, but think that can be up to 5? aboutallpet
    I also need this help. any solution
    • jini55's avatar
      jini55
      jini55 wrote:
      user_error
      V2.3.1.60
      router
      1
      3100
      approx 40' - 50'
      Every help is appreciated
      • FURRYe38's avatar
