ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
JustMakeItWork
You aren't alone. The Orbi has become worse and worse the longer the product stays on the market. I actually think they should revert to the latest stable firmware and just stop trying because they clearly are using the rest of us to test the product. If they really are testing their firmware before release - they need to hire an outside firm to do their testing because the last 4 releases have been increasingly terrible.
I now have a Satellite that won't even connect to the Router. Nobody knows why. If I could return this product to the store, I would. As it stands now, I'm getting to the point where I'm just willing to call it a loss and go buy something else.
