ZoneMaster's avatar
ZoneMaster
Apprentice
Oct 06, 2017
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing!   I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
  • ZoneMaster's avatar
    ZoneMaster
    Apr 29, 2018
    This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
