ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
ZoneMaster
Oct 07, 2017Apprentice
I tried unsuccessfully to roll back to the previous firmware release. Performed another factory reset of all units & installed the previous firmware on the router, but the satellites refused to install. Then the router reloaded itself with 2.0.0.74!
Enable Daisy-Chain Topology is disabled.
Backups to IDrive still constantly disconnecting.
Satellite connectivity seems OK.
Anyone else having IDrive (or other back services) issues?
ejprosse
Oct 07, 2017Tutor
Bought mine from Costco. Was having disconnect issues with the previous firmware, so I upgraded to 2.0.0.74. I work away from home during the week and my kids who need access at night to do homework and my wife who is online throughout the day tell me it's constantly up and down. Combo of devices in the house. iPhones, iPads, Apple TV, Chrome Books, stereo, TV, Xbox 360, Wii, Alexa and a few other things. I get notified when the network drops and I see this throughout the day of a disconnect and reconnect. This is what I have done so far and NOTHING has changed:
Turned off: "Enable WMM" for both 2.4 and 5Ghz.
Turned off: "Enable Daisy-Chain Topology"
I tried turning off the 2.4 frequency, but I have a few items that have issues connecting to 5ghz, but it didn't seem to make it better. All my Apple devices connect at 5ghz anyway.
PLEASE, PLEASE Netgear.... get you engineers on this! If you need my logs, I would be happy to upload them
- ZoneMasterOct 07, 2017Apprentice
My system is also a Costco special. Got it in April. However, in my case the previous firmware worked perfectly & 2.0.0.74 is the problem child!
- aazOct 07, 2017Virtuoso
ejprosse wrote:... I get notified when the network drops and I see this throughout the day of a disconnect and reconnect. This is what I have done so far and NOTHING has changed:
...Have you tried turning off UPnP? I also have the same model with two satellites from costco and that was what resolved the constant drops for me. It appears that there is a camera on my network that was misbehaving with UPnP requests. Since I didn't need it on I've kept it off and the Orbi has been remarkably stable for me - going onto a month and a half now.
- JustMakeItWorkOct 07, 2017Apprentice
Doesn't work. I just had to reset my hardware a few minutes ago even after all the stuff I turned off. This hardware is officially garbage. I've wired up my old Apple router until I can get some Google Wifi's in the morning.
Your post is technically impossible. The .74 firmware that everyone is having an issue with isn't over a month old at this point. How could you be stable for over a month on the .74 firmware if it was just released on 9/22? It's just 10/8.
JustMakeItWork wrote:Your post is technically impossible. The .74 firmware that everyone is having an issue with isn't over a month old at this point. How could you be stable for over a month on the .74 firmware if it was just released on 9/22? It's just 10/8.
I had the stability issue starting in 1.12.x.x. I called Netgear support but they where not very helpful, had me changing my MTU when I know that is not the issue as it was the same as my old router which worked well enough. I tried various settings but noticed the UPnP issue with changes coinciding with the drops of my RDP and VOIP sessions. Turned that off and everything quieted down.
Even after upgrading to 2.0.0.72 and then .74 it has remained rock stable.
