ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
Alex_07
Oct 08, 2017Guide
I had drops connection with the satellite on the v1 firmware but not with the last.
Since this last firmware, i don't have any issues with all options enabled (Implicit BEAMFORMING, MU-MIMO, Fast Roaming).
No issues with xbox one, nintendo switch, nest thermostat, smartphones, tv connected, computers and synology nas connected. Very stable.
Good luck and tell us if you discover a solution.
