ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
madbrain
Oct 08, 2017Luminary
I am having major problems with 2.0.0.74 as well. My phone (Galaxy Note 4) keeps dropping off Wifi and going back to 4G LTE, even when I am stationary right next to the router.
When I disable Orbi (power off all 3 units), and switch to the R7000 (enable its Wifi radio), suddenly everything works - no more dropouts to 4G, except when I move out of the R7000 range.
I'm not paying premium support for Netgear to fix their own bugs.
