ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
Rett_77
Oct 08, 2017Initiate
I've ran in to issues and it seems to coincide with this firmware release as well. Started noticing issues the week of 9/25, but specifically on my Xbox One. Everything else has worked fine. My issue has been when I join a multiplayer lobby with any of my friends and am also in a xbox party with them, I lose connection from the party and get dropped from the multiplayer match. If I'm lucky, I can play one match but otherwise always get dropped at some point. Yet if I play online by myself, without any of my friends in a party, it seems to work ok. I've tried the typically resets, did a factory reset and nothing.
I have my Xbox One hardwired to the RBS50 satellite. I tried just using wifi and had the same results. Never had this issue before. Any one else experience this? I've since downgraded my firmware back to 1.12.0.18 and am testing now. To say the least, it's extremely frustrating. Nothing else has changed. Been running this setup for the past year. Same ISP, no new hardware introduced, etc. And outside of multiplayer on my Xbox, everything else does seem to work ok.
