ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
xBRAWNDOx
Oct 10, 2017Initiate
I can seem to connect to anything but the guest 5 ghz, everytime I type in the password for the standard broadcast I'm told that the password is incorrect, I have to enter the PW 10 times just to get connected, I downgraded to 1.12.0.18 as another forum suggested but it is still not working like it should, my ASUS AC1900 is going to get brought back out if this crap doesn't stop.
