ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
mgdurand1
Nov 26, 2017Luminary
Saw this post while browsing for another issue. I have luckily not had any of the issues you are experiencing with the new formware (2.0.0.74). No disconnects and great range. I see there is a manual update to a new version and I am holding off on that one as the current version seems to be performing for me. Hope you guys can get that worked out.
- TurrmoilDec 03, 2017GuideAny update guys? New firmware or something?
I guess it would be in Jan.- ZoneMasterApr 29, 2018Apprentice
