ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
mgdurand1
Nov 26, 2017Luminary
Saw this post while browsing for another issue. I have luckily not had any of the issues you are experiencing with the new formware (2.0.0.74). No disconnects and great range. I see there is a manual update to a new version and I am holding off on that one as the current version seems to be performing for me. Hope you guys can get that worked out.
Turrmoil
Dec 03, 2017Guide
Any update guys? New firmware or something?
I guess it would be in Jan.
- ZoneMasterApr 29, 2018Apprentice
