arnb's avatar
arnb
Guide
Aug 13, 2020
Missing Devices and Satellites
Installed router and satellites yesterday, Aug 12, 2020
Satellites showed up as connected 5G with good backhaul
Devices displayed 7 of 14 attached and working devices
Decided to power down the router for 2 minutes to see if I could get devices to show.
Now Satellites show as disconnected, but have blue light tops, 3 of 14 working devices show as attached. Yes I did a sync and it seems to have worked.
My frustration levels are rising as I cannot determine status of any of my devices. I'm hoping someone has a workaround or answer for this issue. Thank you.
Additional Background info:
Set my own admin password, ssid and network password, changed Lan Ip address from 192.168.1.1 to 192.168.0.1, added 10 reserved IP addresses. I have 5 (working) Broadlink IR blasters that must be totally reinstalled if  IP, SSID, or password changes, they are a PITA.
  • Why did you change the LAN IP address? What if the IP address that the Orbi is getting is in that range. I suggest putting it back to the default IP. Reboot the Orbi router, then unplug the satellites for 30 seconds or so and plug back in and let them get connected again.
    Make sure all device that are wireless are signed into the wireless network. Regarding wired devices, make sure they are pulling an IP address, and also check cable connection.
    • arnb's avatar
      arnb
      Guide
      I changed the Lan IP address because my prior router's reserved IP addresses were 192.168.0.nnn and Orbi Router rejected addresses. Also have 5 Broadlink rm3 Minis  (IR Blasters) that would need to be totally reinstalled into their app and my Hubitat system, a total nightmare.  Easiest path for me was to duplicate the old network. Yesterday after changing the IP the satellites connected and showed good back haul with 192.168.0.nnn addresses.
  • FURRYe38's avatar
    Do devices appear on the RBRs web page under connected devices?
    • arnb's avatar
      arnb
      Guide
      The internet provider is Optimum Online
      RBR plugged  into  Arris TM822 cable modem
      House about 1800sq ft, one floor, but very long with RBR at one end, RBS daisy chained  about 30ft  from RBR, then 25ft RBS to RBS. Yesterday, connection displayed as "5g good backhaul", and still seems solid, but looking at gui I would not know that.
      • Mstrbig's avatar
        Mstrbig
        Master
        I assume you are coming out of 1 of the 2 LAN ports on the Arris and not the WAN port?
        It absolutely makes no sense that you are functioning, but some of your devices are not showing up.
