dalewebb
Dec 05, 2019Aspirant
Nest X Yale lock disconnects
Orbi RBR40 plus 2 satellites
Have many Nest products including thermostat, Nest Protects, Nest Hello, and a Nest X Yale lock. The Nest x Yale lock keeps dropping it's connection (maybe other devices are too; I don't know). The Nest x Yale tech support agent is blaming the router (Orbi with 2 satellites). Anyone else have trouble with this device? Any clues how to fix it? Firmwear is up-to-date.
Dale Webb
Thank you for all your help. I think I have my modem bridged and the PPPoE set up on the router. Things appear to be working fine.
Thanks again.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). - CrimpOnGuru - Experienced User
dalewebb wrote:The Nest x Yale lock keeps dropping it's connection
"Dropping its connection" can mean different things:
- The device disappears from the Orbi "Attached Devices" display.
- The app that controls the device stops functioning.
Is it correct to assume that the lock appeared to install correctly and operated successfully for a period of time?
How does the lock get reconnected?
Thanks
- dalewebbAspirant
I'll try and answer all your questions:
Model Name Device Name Current Version Status Router RBR40 RBR40 V2.3.5.30 No new firmware version available. Satellite RBW30 Orbi Satellite-1 V2.3.5.6 No new firmware version available. Satellite RBW30 Orbi Satellite-2 V2.3.0.4 No new firmware version available.
What is the Mfr and model# of the ISP modem the NG router is connected too?Zyxel C3000Z
What is the size of your home? Sq Ft? What is the distance between the router and satellite(s)?
About 1200 sq ft. Modem and router are in the basement. Satellite 1 is almost directly above the modem/router in the upstairs. Satellite 2 is about 20 feet from satellite 1.
2.4 Ghz: 11
5 Ghz: 48
Any Wifi Neighbors near by? If so, how many?My phone "sees" about 4 wifi networks. Most are quite weak.
Lock has operated successfully for up to a month, then will go offline (Nest app tells me it is offline. Guess I don't know exactly what that means.) Nest tech support tells me the LOCK is offline. The Nest Connect is working nominally.
Occasionally, it just seems to reconnect without intervention. Usually, I have to remove the batteries for a time and then put them back in to reconnect.
I'll try the suggested changes in your list.
Thank you.
Dale Webb
2.3.5.6 shows as the current firmware for the RBW30. Might be worth a few minutes to download the firmware from the support site:
https://www.netgear.com/support/product/RBW30.aspx#RBW30%20Firmware%20Version%202.3.5.6
Unzip the file, navigate to the satellite web page, and then do a manual firmware update.
What does the Attached Devices display show the lock connected to? (router, satellite1, satellite2)
This has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the size of your home? Sq Ft? What is the distance between the router and satellite(s)?
The distance between the RBWs and RBR is too close. This is probably causing too much wifi signal over lap between these devcies. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- dalewebbAspirant
I called Centurylink to configure my modem (Zyxel C3000Z) to bridging mode and all he had me do was switch the WAN settings from the current PPPoE setting to Transparent Bridging. My internet went away. He said now, I needed to contact Netgear to configure the router. Is there an article somewhere to configure the Orbi router?
