FURRYe38's avatar
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to load an intermediate firmware (2.2.1.212). We need to follow the following update path V2.2.1.210 --> V2.2.1.212 --> V2.3.0.32.
New feature and enhancements:
  • Adds NETGEAR Armor support for SKUs with the RBR50 router. This includes the RBK50, RBK53, RBK50V, and RBK52W.
  • Adds customer firmware pull.
  • Expands the IP reservation function from 64 clients to 253 devices.
  • Adds weak admin password checking
Bug Fixes:
  •  Includes bug fixes for stability when using Ethernet backhaul in large deployments:
    • Wireless backhaul might not change to Ethernet backhaul when an Ethernet cable is connected.
    • Reduces the time to stabilize topology with Ethernet backhaul
    • Reduces the Ethernet backhaul loop that might cause kernel panic
  • Includes bug fixes for stability and performance:
    •    Fixes the LAN/WAN bidirectional throughput on the DHCP mode drop issue.
    •    Fixes the downstream drop issue when port forwarding is enabled.
    •    Fixes the issue where some online games periodicity lag.
    •    Fixes the issue where the PPPOE connection unstable
  • Fixes the issue where the client’s connection type does not display correctly on the Attached Devices page:
    • Wireless client connection will show as wired
    • Client occasionally shows as connected to the wrong satellite
  • Fixes multiple IPV6 issues
  • Fixes an issue related to the SSID containing special characters
  • Fixes the issue where the user sometimes can't register their Orbi Voice
  • Fixes the email address issue on the Security Email page
  • Updates the DDNS No-IP privacy policy
  • Fixes the following security issues:
    • Roll-out NETGEAR Q4 PSV items
  • [MR2.2][Guest Isolation] The guest client can access the GUI via an IPv6 address
Let us know how it works for you...
  • Over the weekend I updated both satellite and routers to the 2.3.0.32 release.  Started with the satellite going to the intermediate (v212) version, then updating to the final release.   Once that was done, I updated the router to intermediate then final release.   I did not perform a factory reset.
    After a couple of days, I am not seeing major connectivity or bandwidth/performance issues.   I am seeing a potential connectivity issue with the Orbi app, however I do not see it when logging into the router via a laptop computer.
    • FURRYe38's avatar
      Is the Orbi system operating in Router or AP mode?
      What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
      What WPA security modes are you using?
      Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
      Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
      Try a factory reset and setup from scratch as last resort.
      • whammy's avatar
        whammy
        Furry,
        Did you even read my post before posting that?
  • Background:
    I have one Orbi main router (RBR50), two indoor satellites (RBS50), and two outdoor satellites (RBS50Y) on a large property. The main Orbi router, indoor Orbi satellites, and outdoor Orbi satellites are generally within 100-150 feet of the main router or nearest satellite. All wifi devices (2.4Mhz and 5Mhz) are within 4-110 feet of the main router, indoor satellite, or outdoor satellite.
    My Experience with Firmwares 2.3.0.32 and 2.3.028 for Indoor and Outdoor Orbi Equip.:
    The newer firmware version 2.3.0.32 for the main router (RBR50) and indoor satellites (RBS50), combined with firmware version 2.3.028 for the outdoor satellites (RBS50Y) helped somewhat, but the following firmware/admin. issues still exist:
    1. The web-based local Orbi admin site (orbilogin.com/index.htm) and the iOS Orbi admin app show conflicting information (e.g. what router a wifi device is connected to, what devices are connected to a satellite, device connection speed, etc.).
    2. It seems to take 24-72 hours for Orbi Outdoor satellites to learn how to connect to a faster/closer Orbi indoor or outdoor satellite with stronger signals..
    3. 2.4G Wifi devices that are in the same garage as an outdoor Orbi satellite (RBS50Y) prefer to connect to indoor Orbi satellites much further away.
    4. Even though all indoor and outdoor satellites show Good backhaul connection speeds, 5G WiFi devices connected to outdoor satellites within about 100 feet show very poor speeds (24-40 Mbps) in.the iOS Orbi admin app. The web-based local Orbi admin site (orbilogin.com/index.htm) does not display Wifi devices' connected speeds.
    Let me know if you need me to help you test a new firmware update.
    • FURRYe38's avatar
      Is Beamforming, MIMO and Daisy Chain enabled on the RBR?
      Daisy Chain enabled will have the satellites piggy back of one another if in a line out from the RBR. Disabled will have the satellites all connect to the RBR separately in a star configuration.
      Try turning down the power output of the RBR from 100% to 75% and test.
      Besure when you having devices turn OFF temporarily, then back ON with the device to see fi the device will connect to hearest satelite device you closest too. It should.
      JBinIL wrote:
      Background:
    • Chuck_M's avatar
      Chuck_M
      Mentor
      JBinIL wrote:
      Background:
      I am interested in your setup as I have a large property with 3 satellites.   Are you using daisy chain or do your sats all report back to the router?  Anything satellite hardwired?
      • JBinIL's avatar
        JBinIL
        Star
        My Orbi outdoor (RBR50Y) and indoor (RBS50) satellites are connected via daisy chain.
  • Netgear is THE MOST CONFUSING PIECE OF CRAP i HAVE EVER SEEN. UPDATEDS... FORGET IT,  log-in...forget it, change passwords...forget it...buy this and waste 2 weeks or more... just saying.
    • FURRYe38's avatar
      So you have R7500?
  • If I save a backup from the 210 FW can I restore that to the 32 FW? I really don't want to have to go through inputting all the static IP's again.
    Right now I have all three satellites updated to 32 and everything seems to be working as expected. I'm hesitent to update the router.
    Is QoS working in the 32 update?
  • Hello All,
    Since upgrading from v2.2.1.210 (via v2.2.1.212), my satellites ( one RBS50 and two RBW30) frequently perform a "config sync". I've performed a factory reset on all devices and it continues to "config sync". Any other ideas?
    • orbilov's avatar
      orbilov
      Apprentice
      Assuming you did upgrade to 2.3.02 after 2.12 pit stop?
    • FURRYe38's avatar
      Is Daisy chain enabled? Try disabling it.
      1midniterider wrote:
      Hello All,
      • spas's avatar
        spas
        Guide
        Thanks to all responders...I reverted back to .210 on the router and both satelittes this morning... So far, so good - All issues --> gone...
        - traffic meter working again,
        - IOS app (2.3.0.31) correcly displaying (STAR) topology,
        - Web GUI - no more satellite "config sync" bounces, satelittes show "good" all the time
        - no internet drops.
        - devices already connecting to closest Orbi
        I guess I'll wait till the next firmware release before thinking about upgrading...
        Cheers!
    • SW_'s avatar
      SW_
      Prodigy
      1midniterider
      You are not alone with this problem.  I ran into the exact same issue post upgrade from v210 to v32.  Don't waste time with Factory Reset or any configurations fiddling, it won't resolve the 'config_sync' vicious cycles problem.  The Satellites will have connection problem when this happens.  You can verify this by going to RBR50 Firmware Update page.  The Satellites would say "Waiting for connection" instead of "No new firmware version available".   The latest Orbi app will also go crazy trying to determine the network map topology.  The network map will change constantly on every other refresh.
      The solution that works for me was to revert back to v210.  I'm sticking with v210 until the next firmware release.
      • spas's avatar
        spas
        Guide
        I reverted back to .210 yesterday and everything is back to normal except traffic meter. I’m with you on waiting to the next firmware upgrade.
  • I upgraded this past weekend. So far things seem stable. I have not confirmed any fixes for problems I was experiencing - I have to get a few reboots under my belt to see if the sporadic DHCP problem is solved.
    I still see devices on the attached devices page showing as connected to non-existent satellites. My satellites are named Orbi-Sat-1 and Orbi-Sat-2, and while I see devices listed as connected to both of these and my router, I also see devices that show as connected to "Orbi Satellite". It appears to be related to a page refresh issue - once the page is done refreshing, these typically update to one of my satellites. The page appears to have an automatic refresh feature, and the refresh also often takes longer than it should. So the page seems a little unstable in how it refreshes. I think it would make more sense for the connected Orbi column to be empty until it can be populated with the real value.
  • All, when will USB hdd be available? I have effectively downgraded... Any news greatly appreciated.
  • FURRYe38's avatar
    I fully agree with everyone on the FW update issue. Seems that in history, NG has been pretty good at doing updates. However seems like over the past several years this process has become more and more problematic. I see this even on there R and XR router series. I agree, users should not really have to worry about the operation of there HW after a update and should be able to upate and continue to use the HW with out any kind of intervention. Just sesms like development and testing at NG has changed over the years. I presume this also mabye due to the fact that the core FW isn't developed my NG anymore. I see more and more 3rd party chip set Mfrs and develop companies doing different areas of the router base. You have CPU, WiFi and QoS, some all using different or same 3rd party chip sets and developers. Then router Mfrs put all this together and who knows what kind of testing is actually done before released as a beta or officially to the public. I wish Mfr would stop relying upon ther customers to do there testing. :smileyfrustrated: Ya is kewl for those of us who want to do beta testing. Helps find some issues. However when it's comes to just the average user, should have to be messing around like this. :smileymad:
    • dklimas's avatar
      dklimas
      Apprentice
      I updated the router and all three satellites to .44 after the web UI seemed to reset on it's own and most my settings were set back to defualt. Still haven't reassigned all 40 static IP's but no weird issues so far. Daisy chain is checked and the satellites are cleary in star configuration in the app though.
      Everything seems to be working as expected for the past week. Coverage and speed is really good. No error messages on my mobile about WiFi calling.
      I got around the lack of device usage tracking by purchasing a Firewalla Blue firewall. It allows me to see what each device is doing at any given time. Very happy with it.
      • FURRYe38's avatar
        After setting up the router again, do a backup of the configuration for safe keeping.
        Thanks for letting us know your experinece.
  • Why is the older firmware, which I evdiently need, not available on NETGEAR's site.  I have tried following a link or two in this community, and it takes me to a DropBox location.  I am not at all comfortable downloading from there to be honest as this has given me some "unwanted gifts" in the past.
    It would be so nice if instead of telling me I need to download the old software before updating to the newest software that a link for that from a secure website for NETGEAR would be provided.  Can someone please assist?
    Ben
    • FURRYe38's avatar
      What version are you looking for?
      All files that were released are on the download site for each model Orbi.
      I recommend using v60 as it seems to be stable now and works well for others.
      Ben
