ryanjohn04's avatar
Dec 25, 2017
No Internet Connection
Anyone ever have this issue?  Anything that is always connected to the wifi (i.e. cameras) have no issues.  But things that connect and disconnect (i.e. iphone, macbooks) sometimes come up with the *No Internet Connection error in WiFi setup.  It goes away after 2 or 3 minutes of trying but is frustrating.  Also, if unplug all the orbis and "reset" everything it works for a day or two then I start getting the No Internet Connection error when I try to connect intially for a few mins.
Thanks
  • Same for me.  Getting old.  Net gear needs to step up and take a bigger interest in all these mounting problems.
  • Yep, same for my iPad as it is connected to my wifi but gives no internet. If I flip the wifi off/on on my iPad it comes works again but I shouldn’t have to do that. Agree that its something suspicious with devices that “sleep” or connect/disconnect like mentioned.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    In the advanced wireless settings try to uncheck the 20/40 MHz see if this helps with able devices.
    DarrenM
    • jeffholiday's avatar
      jeffholiday
      Guide
      Will give it a try as I just unchecked it now. Will this cause any issues with other devices that I might have connected? Just curious how this might resolve the problem.
    • ryanjohn04's avatar
      ryanjohn04
      Guide
      Hi Darren- appreciate the followup, but won't this just keep everything at 40Mhz and from what you said we need to force things onto 20Mhz.
  • DarrenM's avatar
    DarrenM
    Apple devices do not recommend using the 40mhz on the 2.4ghz band since you are having issues with IPads this may help.
    From Apple
    2.4 GHz channel width
    Channel width controls how large of a ”pipe” is available to transfer data. However, larger channels are more subject to interference and more likely to interfere with other devices. A 40 MHz channel is sometimes called a wide channel, and a 20 MHz channel is a narrow channel.
    Set to: 20 MHz
    Use 20 MHz channels in the 2.4 GHz band. Using 40 MHz channels in the 2.4 GHz band can cause performance and reliability issues with your network, especially in the presence of other Wi-Fi networks and other 2.4 GHz devices. A 40 MHz channel might also cause interference and issues with other devices that use this band, such as Bluetooth devices, cordless phones, and neighboring Wi-Fi networks. Routers that don't support 40 MHz channels in the 2.4 GHz band do support 20 MHz channels.
    DarrenM
    • guzzijason's avatar
      guzzijason
      Apprentice
      For what its worth, that's a general recommendation for any devices using 2.4 GHz in congested areas - not really specific to Apple in any way. It can cause interference problems - it's a problem with the protocol, not with the devices.
      • Jrsjammin6180's avatar
        Jrsjammin6180
        So Darren just to clarify. If the 20/40 box is checked is it running in 20 or 40 or both. Please see Eric90i comment.
        Checked or unchecked 20/40 box? Thanks
  • Same issue here. I’m running latest firmware (didn’t have issue previously or didn’t notice it). Anyone have luck with the change Darren suggested?
      Jrsjammin6180
      Yes I’ve tried what he said and it may be a bit more stable. What really helped was trying the following which support suggested.
      See below.........
      At this moment, I do suggest the following:
      A) Change the Channel of the Orbi's WiFi. Select 11, 9,6, or 1 for 2.4GHz and 48 or 44 for 5GHz. Apply to have your changes take effect. Then, observe the connection. ADVANCED> Setup> Wireless Setup.
      B) Disable both Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices and Enable MU-MIMO under Wireless Settings. Observe. You can also enable these then also observe the connection again. ADVANCED> Advanced Setup> Wireless Settings.
      I changed my 2.4GHz to 11 and 5GHz to 44
      I also turned on “beam forming “ and the MU-MIMO which were not previously on. This has been the most stable it’s been after they messed with the firmware versions. I bought in May and it was a huge success until I updated firmware. Hope this helps.
  • Thanks for the suggestions. Trying out some variations.
    One comment though: when I unchecked 20/40mhz coexistence, I scanned my WiFi and found both 2.4ghz bands to be running in 40mhz. I feel that the unchecking of that feature only enables 40mhz. I checked the box again and scanned WiFi, this time it showed 20mhz was active again for 2.4ghz.
      guzzijason
      Apprentice
      Ah, yes... 20/40 coexistence means that it will automatically drop from 40 to 20 if there is interference. If you disable that, it locks it into 40 MHz only it seems.
  • Yup - after several days of cameras dropping offline, they’re all working (as is Alexa) but cell phones and iPads get no internet connection. It’s happening right now while i listen to Alexa as I type this. Very frustrated with this system having spent hours resetting etc.
    • DarrenM's avatar
      DarrenM
      Hello Rowie01
      What firmware version are you on? if you are on the 2.1 firmware have you tried to roll back to 2.0.1.4?
      DarrenM
    • FURRYe38's avatar
      What the Mfr and model# of the ISP modem that Orbi system is connected too?
      Try disbling Beamforming, MIMO and Daisy chaining. Some of said this has helped stablize the system in some cases.
