ploo
Oct 13, 2018Guide
Orbi 2.2.1.210 fimware security issue (turns on guest network with no password)
Has anyone else experienced this? I upgraded by Orbi to 2.2.1.210 - everything seemed fine. I have a guest network (with a password) that I leave disabled and only enable when we have a guest. It is ...
Oct 13, 2018Guru - Experienced User
Try FW re-load and full factory reset and setup from scratch:
Does it still occur after this?
ploo
Oct 13, 2018Guide
I have already fixed it as I described - namely, by turning the guest network on and back off again.
I was however, highlighting the issue that this may happen when the firmeware is updated and it shouldn't happen. It was pure chance that I noticed this and my network had been completely open for several days as a result.
- FURRYe38Oct 13, 2018Guru - Experienced User
Would need to try a factory reset and setup from scratch to see if this is something that changed in the new FW. Something NG will need to know.
- toeOct 13, 2018Apprentice
Stop asking customers to do factory reset and other time wasting procedures that is not part of the instruction from Netgear themselves and hoping that it fixes something. Netgear should be the one doing the testing with new firmware releases to ensure integrity of previous configurations during upgrade. I think you might think that is helpful, but plenty of customers have wasted some many hours of their time doing unnecessary resets.
Sorry, this is a valid proceedure to do as others have said it's worked for them:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
https://community.netgear.com/t5/Orbi/RBK40-Download-Speed-Slows-Down-After-5-Days/m-p/1643475/highlight/true#M41776
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1548414/highlight/true#M27868
https://community.netgear.com/t5/Orbi/speed-slows-down-Orbi/m-p/1551822/highlight/true#M28289
https://community.netgear.com/t5/Orbi/Is-2-1-3-4-in-auto-update/m-p/1553979/highlight/true#M28616
https://community.netgear.com/t5/Orbi/Orbi-Satellite-RBS50-Not-Connecting-via-Ethernet/m-p/1556692/highlight/false#M28949I'll keep posted as I see fix. Thank you.
