DESIi1
May 02, 2017Star
Orbi backhall signal dropping to Zero
When I upgraded to the latest firmware the backhall signal started to drop to zero. It was smooth prior to the upgrade. This has to degrade performance. See below. What can be done?
- CRamosmiaAspirantI am on the latest firmware and when android devices connect to the 2nd or satellite Orbi. The connection to the device fails and recoonects sporadically. Thoughts?
Orbi was working great until about a month ago.
Orbi was working great until about a month ago.Have you tried either turning on or off the MIMO and Beam Forming? Suggest switching one at a time.
- nkdApprentice
My performance has truly gone to **bleep** with my units. I sware it was so good before. I am gonna check if there is a firmware downgrade available. My satellites used to get me almost my gig speeds, nothing has changed. Now I get 20-30mbps when I connect to satellites. When I go downstairs and run speedtest on hard wired computer I get almost a 1gig connection. I am truly disappointed in the **bleep** the product has turned in to with updates. This is why if its working fine don't upgrade. Netgear seems to be braking a truly amazing product.
- Doug makes some strong points here.
Just some thoughts:
Why are you guys thinking the one scanning software with a specific adapter on a specific device is the setup that is accurate while every other configuration shows backhaul instability? I would think that one scenario where it looks stable is the outlier of all these tests.
It's also weird that no other hidden network from any router shows drops. If the software and adapters cant read hidden SSIDs correctly, why is orbi the only one dropping?
Finally, it seems premature to brush off this backhaul problem since 90% of troubleshooting posts refer to problems from the satellite exclusively. Doesn't that point to the backhaul as it's the sole source of data going to the satellite?there are some different issues at this time and the one we are referring to is the orbi router and sat that is perfectly stable yet reports with the apps that the signal drops in and out constantly as shown in the pics above
where testing shows that the backhaul signal by doing some form of transfer has no issue but the testing app shows the drops , this is a specific reporting issue and compatability issue with certain adapters and the drivers in the app's
others have different issues that do certainly drop the connection and or clients but with regards to this situation they are not related
- DarrenMSr. NETGEAR Moderator
The latest firmware is out with alot of dissconnect fixes can someone that is having backhaul drop outs let me know if this firmware has resolved this issue for you? If not we would like to work with you on the issues.
Thanks
DarrenM
- MrMagoo122InitiateGood morning peteytesting,
How are we supposed to read the apps correctly? This sounds like my issues but I want to verify.
Can you attest that there is no problem with the backhall?
Thank you- rhester72Virtuoso
My research on backhaul in the past 2-3 weeks indeed suggests that the 'dropouts' observed are an instrumentation issue on the part of the measurement tool(s) and are *not* indicative of actual loss of signal, as verified by a few people now (including myself) doing fire-and-forget UDP during the periods of 'loss'.
Rodney
- Doug-48051Luminary
3 Points to make here:
1. Had the NAS hooked to Orbi router for 18 days, No connection Loss reported by NAS. Moved NAS to SAT, connection loss reported everyday connect to SAT.
2. During these outages the NAS was not accessable. So I am not relying on just a software notification.
3. LogiCircle cam is 6ft (straight in front) of SAT and signal strength drops to 5%. I am not adding cam to this issue. b/c the cam is wireless. BUT I dont understand a WIRED device reporting drops ONLY on the SAT??? Not on the Orbi Router.
Maybe the situation is different. If you would like me to perform something specific, please post the process.
Thanks
- st_shawMaster
MrMagoo122 I have tested this quite a bit. It's a matter of using one of a very few combinations of: 1) wifi adapter, 2) device driver, 3) operating system, and 4) WiFi scanning app that can effectively "sniff" wifi packets as required to sample the backhaul.
I have confirmed you can use Acrylic WiFi Professional on Windows10 with a Netgear AC6200 v1 (Broadcom chipset) USB adapter and get a reliable graph of the backhaul. But, you must use the Acrylic NDIS driver, put the adapter in Monitor mode, and lock the WiFi adapter on the backhaul channel (157 for me), or at least limit channel scanning to 5GHz channels only.
If you don't use a scanning setup that supports monitor mode and that allows control of the channel-scanning, you will miss some of the backhaul packets because the scanner is busy scanning other channels. Some software will report this as a drop in signal.
- Retired_MemberAnswer: Simple denial and pretending they haven't seen the threads.
Such a disappointment.- gasongasoffInitiate
Any updates? Will flashing back to a prior firmware solve the issue?
the issue seems to one of incorrect reading of the apps with certain wireless adapters used rather than an actual backhaul issue , rolling back fw wont help as the orbi will just roll it forward again , new fw wont be far of and should fix a lot of connectivity issues according to those in the community using the latest beta fw
- Retired_Memberst_shaw, first thanks again for posting more results. From reading the inSSIDer blog it sounds like those they list are only some they know will show a hidden SSID. It sounds like if the adapter did not support hidden SSID's then it would show nothing instead of a dropping signal. Personally I don't think it has anything to do with the ability to read the signal but it has everything to do with the scanning interval.
In those graphs you posted, it shows several minutes and a drop that lasts might not show up. The images I posted were probably 30 seconds max for the entire graph.
I'm not quite ready to buy a new adapter because I can already see the backhaul just fine and it looks exactly the same on every device I've tried. You may very well have a backhaul that doesn't drop but that would make you the first with those results.
If connections were solid and I had no disconnects, I wouldn't care what the backhaul was,doing. But as long as my Wi-Fi is dropping constantly when I connect to the satellite, I'm going to keep blaming the backhaul which is also dropping on my Orbi at least. If the backhaul is stable and we are all reading the graphs wrong, Netgear should be jumping up and down telling us this so we can stop the witch hunt. But of course they blatantly ignore any mention of the backhaul except for the one post saying to contact support. This sure seems like a hardware fault and users are considering a class action suit over it. Netgear could easily **bleep** that in the bud if it's nothing to worry about.
I have not run any file transfer tests but I have done a simple ping test to google from a satellite connected laptop and the results are erratic. Around 20ms for multiple pings and then close to 1s out of nowhere.- JMU1998Luminary
I am sure Netgear Engineering has read about this issue on this thread so what has Netgear has to say? how is it going to be fixed after internally reproducing It? do we get a Refund? A Hardware upgrade(with the fix)? Or just simple denial?
- AlcarnorInitiate
I'm seeing the dropouts on the pixel as well, but also on the several android devices, have noticed the power drain issue since setting up Orbi. It's gotten a bit better with the current firmware, but nowhere near where it ought to be.
Also saw the dropouts on Wifi Analyzer on the Pixel. (short interval for scans will show it; the netgear analyzer has too long a default scan time)
When it works, it's great.Nice and fast. I might have to unplug the satellite to see if that helps at all. (And as others have noted, what's the point of the Orbi if it doesn't work with the satellites?)
- David-T-RexInitiate
I have to throw my hat into the dropout ring as well.
when it works, its great and most of the time is not a major issue - but when I am streaming plex/netflix etc its a royal PITA.
- OrbiManLuminaryAlso guys please note that backhual drop only occurred for 1-2 seconds at most. If your wifi analyzes every 5 secs u won't see it. Pay attention to the time unit
- Retired_MemberI used the Netgear Wi-Fi Analytics and Wi-Fi Analyzer on different phones that were all on Android 7. I used inSSIDer on a Windows 10 laptop. I didn't have a Mac to try on.
Support had me install Wireshark and send them logs a while back. I didn't know how to interpret the results either but there were a lot of intermittent red and black rows. They would never tell me if they saw anything unusual.- st_shawMaster
I did more testing this weekend with a couple 802.11ac USB adpaters. My conclusion is still the same-->Whether the backhaul appears stable depends upon the wifi adapter and wifi scanning software used to make the measurement. This is because detection of hidden SSIDs is poorly supported by common chipsets and scanning software.
Most combinations of software and wifi adapter I have tried do not properly capture the Orbi's hidden SSID backhaul signal. The signal is either spotty or not shown at all. I have an Techncolor AP with a hidden SSID and it behaves the same as Orbi's hidden SSID.
According to Netspot Pro, their software will only work properly if you connect to the hidden SSID. That's not an option with Orbi.
inSSIDer says their software does not officially support hidden SSIDs. inSSIDer Office on a Mac will not show the Orbi backhaul or hidden SSIDs at all. However, inSSIDer folks say certain WiFi chipsets will work under WIndows.
One of my cheap USB WiFi adapters, an Edimax EW-7811UTC, happens to have a chipset that inSSIDer says works with hidden SSIDs. I was able to capture solid graphs of the Orbi backhaul with Windows 10, inSSIDer Office, and this adapter.
Retired_Member You said you have inSSIDer on a Windows 10 laptop. I haven't seen any plots you shared from that setup, so I assume the results were spotty also. Will you please get one of these Edimax adapters ($15) use it with inSSIDer and Windows 10 to measure your backhaul? The results should be very interesting.
hi st
i thought that may have been the case as i too have noticed it all depends on the adapter and or software used , have even tested this by running a transfer over the link and watching its prograss while at the same time watching the backhaul link , the backhaul link can show drops but the transfer remain solid
not saying its the only reason but it certainly does look like in this case its more a reporting issue than a hardware / software issue of the orbi
- Retired_MemberJust checked and the 2013 Galaxy Tab 3 doesn't have ac Wi-Fi. That must have something to do with the results.
- st_shawMaster
Right. No AC, but it has a 5GHz a/n radio and that should be all that's required, based on inssider's documentation of approved WiFi cards anyway. They say:
802.11ac Support
If you want to make sure that you can scan for 802.11ac networks, all you need is a 5 GHz a/n compatible adapter.
All 802.11ac management traffic is backwards compatible with 802.11a/n, so we can find out everything we need to know about an 802.11ac network with an 802.11a/n adapter.
I can see the probe requests from the Samsung and the probe responses back from ac APs on wireshark, so it's working. And, the Tab 3 is the only device that reports a stable backhaul!
