kevin_gee's avatar
kevin_gee
ORbi RBK53 Dropouts & Logs
So, unfortunately I paid a lot of money for this rbk53 system. It worked great for about 2 weeks and then nothing but dropouts and resets later I would really like a solution.
I am using virgin media 350mb service. I use their own supplied modem/router. The Orbi router is less than 1 meter from the Virgin setup and I have the other 2 satellites around my home.
Network map looks ok on the app. Most of the time they are all green, sometimes yellow sometimes red, its pot luck.
I'm no tecchy, so I really need to know where to find the logs for the orbi system so I know what is at fault, the orbi or my internet connection.
I have all firmware up to date. Any advice is welcome
  • FURRYe38's avatar
    If your ISP modem already has a built in router, then this could be a problem. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
  • CrimpOn's avatar
    CrimpOn
    Netgear provides 90 days of "complimentary support" with the purchase of an Orbi system.  There is a link on the product registration page to "Contact Support".  Since you paid for it, that is one possibility to consider.
    Orbi "logs" are not part of the Orbi "app" interface.  There is a debug facility on the Orbi web interface which produces tons of information.  Whether any of the data is relevant to your situation is a question better addressed by Netgear support.  I just produced a debug file from my Orbi while researching a different issue, and the quantity of data is overwhelming.
    • kevin_gee's avatar
      kevin_gee
      ive now got my home hub 3 router now set as a modem and the orbi as router. it too many many attempts from the oribi to see the internet, and eventually it worked, took about 20 retrys. I knew I had it setup correctly. So it eventually connected.
      I'll see how this goes for a while and monitor
      I do have an r7800 x4s but I dont want to use the orbi as an AP but then again the qos is good, I dont think the orbi uses it but I'll see how it goes with throttling before i make anymore changes
      • FURRYe38's avatar
        Sometimes you have to turn OFF the modem and RBR for 30 seconds then back on with the modem first, then the RBR lastly.
        Glad you got it going finally. Let it run for a while and see. You should be ok.
      • FURRYe38's avatar
        So try the modem in router mode and set the Orbi for AP mode and see how it goes.
        Contact NG support for additional help and information.
        Good Luck.
    • Papatango's avatar
      Papatango
      Disable daylight saving in settings and there will be no more dropouts.
      • FURRYe38's avatar
        Hmmm haven't seen this with mine. Daylight savings is enabled. Could be something else...that is effecting DST...
