AIRgauge
Mar 10, 2020Aspirant
Orbi RBR/RBS50 not syncing and connected devices not showing
I'm currently running firmware version 2.5.1.8 on both the router and the satellite. Up until recently they were working reliably and the system has been great. Two things may have affected that and I'm not sure which. We recently added a Ring doorbell to our home network and it doesn't stay connected consistently. We also had a recent very brief power outage and now the satellite doesn't sync with the router, and the connected devices don't show up. They are connected and do function, but the backhaul status shows as disconnected so connections do sometimes drop. I can see the list of devices that have permission to be on the network, but they don't show up as connected. The number of connected devices shows as anywhere between 1 and 5 and varies from time to time.
I've seen other users with similar problems where the solution seems to be to manually update the firmware to the version I'm running. Not sure what to do to fix this?
A manual firmware update is not the solution, because the Orbi is already on the most recent release.
What steps have already been tried:
Power them both off.
Power up the Orbi and wait until it comes up, which takes a LOT longer than I expect it to.
Power up the satellite.
Does that have an effect?
The "last resort" is to perform a "Factory Reset" on the system, based on the theory that "something got corrupted" in operating memory by the power outage and that "starting fresh" will create all the internals correctly. Depending on how much was done to customize the Orbi (device assignments, defining device names, customizing DNS entries, setting up DDNS & VPN, etc. etc.) this can be a serious effort.
This is usually done in two ways: (1) before the reset, save a copy of the configuration file to an external computer. This is on the Orbi web interface, Administration, Backukp Settings. After the reset, there will be a chance to "restore previous settings". So, way 1 is not painful at all. (2) However, if way 1 fails to solve the problem, The second method is to say, "Nope. I am setting this up manually", and enter every blasted item by hand. My tactic is to NOT set the Orbi WiFi name until the very last. With a different name, no devices will connect to the Orbi and mess up my configuration process. After all entries are done, I change the name, the Orbi restarts, and it's a wild scramble as all the devices connect. In order to do this, I make screen captures of every single page of the Orbi web interface and save them in a Word file.
The Factory Reset process is explained in this video: https://www.youtube.com/watch?v=cMw4ePACgc4
- AIRgaugeAspirant
I have tried the steps you described and it changes the number of connected devices that show up, but the number is not accurate and the satellite still doesn't sync.
Thanks for the links and info on factory resetting - hope I don't have to go that route but that helps if I do.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
AIRgauge wrote:I'm currently running firmware version 2.5.1.8 on both the router and the satellite. Up until recently they were working reliably and the system has been great. Two things may have affected that and I'm not sure which. We recently added a Ring doorbell to our home network and it doesn't stay connected consistently. We also had a recent very brief power outage and now the satellite doesn't sync with the router, and the connected devices don't show up. They are connected and do function, but the backhaul status shows as disconnected so connections do sometimes drop. I can see the list of devices that have permission to be on the network, but they don't show up as connected. The number of connected devices shows as anywhere between 1 and 5 and varies from time to time.
- AIRgaugeAspirant
What is the Mfr and model# of the ISP modem the NG router is connected too? CICSO DPC3849V - provided by my cable provider and our cable also runs through it.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router30 feet, separated by one floor, and always worked perfectly until now. When I plug the satellite in, it shows a blue circle after it connects to the network, but does not sync.
Any Wifi Neighbors near by? If so, how many?I have tried changing channels as you described but no luck. We have 9 wifi neighbours nearby.
Tried this - it didn't help.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Don't have Armor or Circle enabled, but will try the others.
Seems that you may have a ISP modem with built in router and wifi.
Do you know what mode the modem is working in? Router or Bridged?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry removing the RBS from the RBRs web page. Then factory reset the RBS by pressing the back reset button for 15 seconds then release. Once the top ring LED slowly pulsates WHITE, press the black sync button on the RBR then on the RBS. I would do this with the RBS in the same room as the RBR. If you get it sync'd, then place back in remote location.
A reset of the RBR maybe needed as last resort.
- Anonymous
How did you end up with 2.5.1.8? How long have you had it? Was your system working before 2.5.1.8?
- AIRgaugeAspirant
I have automatic updates set via the app. I'm not certain how long I've had it as it was set to automatically update, but it has always worked reliably until now.
- Anonymous
AIRgauge wrote:I have automatic updates set via the app. I'm not certain how long I've had it as it was set to automatically update, but it has always worked reliably until now.
So you didn't manually perform the FW update and you have no idea how long you've had it?
My recommendation: Roll your FW back to the previous version....OR...continue on with what you see here.:smileysad:
- NJC1Aspirant
Has anybody found a solution to this. I thought everything was working and moved the satelite, reconnected with the blue ring...
Just found a device near the satelite was showing as out of range, checked the satelite on the webpage to see whilst it is conencted, the backhaul is not.
I haver the satelite on the same desk as the base now so i could try and fix this easily... not luck
Tried the steps others have done too without success except for reverting to an earlier FW version. Not sure how to do that.
- Anonymous
NJC1 wrote:Has anybody found a solution to this. I thought everything was working and moved the satelite, reconnected with the blue ring...
Go to downloads and enter your model number
- NJC1Aspirant
Thank you,
I just tried a router reboot again and the backhaul reconnected this time.
