Desmond_Lau
Jun 07, 2017Star
Orbi Router - QOS Setup
When I go to QOS setting, only see "Speedtest - powered by OOKxx", When I click the speedtest button, it will take a long time to run. After that, I go to Satellite to check "Connected Device", the message box "Please wait a moment" popup. But nothing refresh. I think this is a bug.... anyone can test it?
The solution for "Please wait a moment", I need to restore my backup setting (FW version V1.10.1.2).
QoS is disabled when Orbi is set to AP mode:
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Do you have Orbi set up as a Router or in AP mode? If you have it set to AP mode the speedtest is all that will show up under QoS as everything else is disabled.
I just installed a new RBK53 on Sunday. It is running the latest FW, and it is in Router Mode, but the only thing that appears under QoS Setup is Speedtest.
- OrbiPhilipLuminary
Same here for AC3000 running V1.10.1.2. I see speedtest and nothing else. Speed test works, but that's all that tab does.
I work from home and need to be able to prioritize my VOIP phone. It will not be recognized by the Orbi as RTP because the stream is inside a VPN tunnel. Even if it was recognized, I need to ensure that it has priority above all the other RTP devices that are streaming entertainment.
This was easy on the WRT54G running DD-WRT. I simply set the MAC of the VOIP device to highest priority.- SKKGuide
When will Netgear officially support QOS on Orbi ? I have the exact same issue and get occasional disconnects on my main PC and ipphone and want to prioritize them.
I also have this issue. I have 2 IP cameras that consistently stop working with the Orbi, but they keep their IP. I am trying to add some QoS prioritization to these cameras in hopes that it maybe makes a difference. With this page being basically blank, I cannot do this.
If in your browser you enter the following after you log in - it will show a QoS page.
/QOS_dynamic.htm
However - when I try this I'm not able to actually "Apply" those settings.
Anyone know how to solve that?- BravoRomeoInitiate
I was able to Apply change on that /QOS_dynamic.htm page by very carefully hovering the mouse on the bottom edge of the Apply button. It seems the page is unfinished and untested. Nevertheless, after hitting Apply I received a dialog about sending my MAC address to "the provider", then had to check the Dynamic QOS box again and hit Apply a seccond time. It stuck. No idea if it actually works. I'm about ready to use Orbi as an access point and move to Mikrotik for more capable routing.
While I was finally able to click "apply" thanks to your advice - I'm still not able to see where/how we can set the priority of how devices are connected to the internet. I have a wireless CPI camera (security) and often it keeps 'dropping' the wifi signal. There seems to be no rhyme or reason as to when this happens. I'd like to make it a higher priority to see if that will fix the problem.
Any ideas?
