bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
Aug 10, 2018Guru - Experienced User
I would post about this here in the Pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
Rennce wrote:
Howdy,
I have the Orbi Pro but have been experiencing the satellite dropping connectivity several times a day for weeks. I had tried many of the suggestions but nothing seemed to help. So today I added a DHCP reservation for the satellite IP/MAC and have not had a single issue since. Yes it is early days but given I was having several drop outs every hour perhaps it has worked.
Cheers
Rennce
SRS60 with 1 Satellite
Firnware: V2.1.4.16
nvt
Aug 20, 2018Apprentice
I'll save you the trouble - this device does not work. It appears to work for some people but there is a cadre of people including myself that the unit reboots, resets and disconnects no matter what you do.
You can see another unhappy "customer"
https://community.netgear.com/t5/Orbi/Orbi-is-a-Complete-Netgear-Failure/m-p/1495506
The most troubling aspect of this in my case is that this is not WiFi but Wired as well as WiFi. I have hard wired Cat5 throughout the house and I have watched the system die on the wired connection bringing my whole house network to a standstill. In one case unresolved for 3 days. A replacement unit worked for the first few hours and then same problems recurred
Tech support is nothing of the sort for these "Business" class devices and support
I have the logs to prove the disconnects that occur with depressing frequency but unpredictably. Here's the most recent set of logs for my Synology *wired* device and the sequence of connects and disconnects
Connection to <NAS-EXTERNAL-ID> has been lost since 2018-08-19 12:00:25 -04:00
Connection to <NAS-EXTERNAL-ID> has been resumed since 2018-08-19 13:53:32 -04:00
Connection to <NAS-EXTERNAL-ID> has been lost since 2018-08-19 14:13:05 -04:00
Connection to <NAS-EXTERNAL-ID> has been resumed since 2018-08-19 16:43:20 -04:00
Connection to <NAS-EXTERNAL-ID> has been lost since 2018-08-19 16:43:20 -04:00
Connection to <NAS-EXTERNAL-ID> has been resumed since 2018-08-19 22:05:55 -04:00
Connection to <NAS-EXTERNAL-ID> has been lost since 2018-08-19 22:17:26 -04:00
Connection to <NAS-EXTERNAL-ID> has been resumed since 2018-08-20 00:36:24 -04:00
Connection to <NAS-EXTERNAL-ID> has been lost since 2018-08-20 00:36:24 -04:00
Connection to <NAS-EXTERNAL-ID> has been resumed since 2018-08-20 01:17:48 -04:00
Connection to <NAS-EXTERNAL-ID> has been lost since 2018-08-20 01:57:06 -04:00
Connection to <NAS-EXTERNAL-ID> has been resumed since 2018-08-20 04:57:23 -04:00
Connection to <NAS-EXTERNAL-ID> has been lost since 2018-08-20 04:57:23 -04:00
Connection to <NAS-EXTERNAL-ID> has been resumed since 2018-08-20 08:30:20 -04:00
As for the support line that I personally have spent over 3 1/2 hours sometimes being bounced from dept to dept but mostly on hold listening to irritating hold music. Ultimately I am promised a call back (within 60 secs of a disconnect) - never happened
Or from Orbi Business Level 2 Support within 10-15 minutes - 5 hours later still waiting
Each time you call you must go through regular support as they refuse to provide you with an access number to call the support line direct
Lucky for the folks who's devices are working but mine is definitely not and I have been troubleshooting since I bought it end of Jun 2018
- FURRYe38Aug 20, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Ethernet Backhaul: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-10-kills-Internet-access-if-you-use-Ethernet-back/m-p/1603922/highlight/true#M35521
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highlight/true#M34020
Another initial setup process: https://community.netgear.com/t5/Orbi/Backhaul-breaks-the-whole-network/m-p/1615770/highlight/true#M38393Working after resets:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1548414/highlight/true#M27868
https://community.netgear.com/t5/Orbi/speed-slows-down-Orbi/m-p/1551822/highlight/true#M28289
https://community.netgear.com/t5/Orbi/Is-2-1-3-4-in-auto-update/m-p/1553979/highlight/true#M28616
https://community.netgear.com/t5/Orbi/Orbi-Satellite-RBS50-Not-Connecting-via-Ethernet/m-p/1556692/highlight/false#M28949
- QuickscanAug 20, 2018Guideyep, it doesn’t work properly and you can mess about with firmware, factory resets, relocation etc as much as you like but there is a fundamental hardware issue with Orbi that doubtless Netgear are trying hard to bury. My guess is that most Orbi owners are affected by the signal drops but because it reconnects in 30 secs or so it’s only people on conference calls all day or multi hour live streaming who would notice. I get about 4 or 5 drops a day but know now to do a manual reconnect in the network settings a second after it drops and i find it reconnects almost instantaneously. When it’s working it’s great but clearly they rushed it to market without proper testing because there is a fundamental issue with it. To all the people who send long technical responses about how this could be fixed with endless messing around with daisy, mu mu, location and firmware advice they are missing the point. The whole attraction and sales pitch of Orbi is that it works out of the box, it’s sold as a household consumer product that doesn’t require networking expertise. That’s why ultimately it’s a failure.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Not everyone is having problems with there Orbi systems...
Quickscan wrote:
yep, it doesn’t work properly and you can mess about with firmware, factory resets, relocation etc as much as you like but there is a fundamental hardware issue with Orbi that doubtless Netgear are trying hard to bury. My guess is that most Orbi owners are affected by the signal drops but because it reconnects in 30 secs or so it’s only people on conference calls all day or multi hour live streaming who would notice. I get about 4 or 5 drops a day but know now to do a manual reconnect in the network settings a second after it drops and i find it reconnects almost instantaneously. When it’s working it’s great but clearly they rushed it to market without proper testing because there is a fundamental issue with it. To all the people who send long technical responses about how this could be fixed with endless messing around with daisy, mu mu, location and firmware advice they are missing the point. The whole attraction and sales pitch of Orbi is that it works out of the box, it’s sold as a household consumer product that doesn’t require networking expertise. That’s why ultimately it’s a failure. - nvtAug 20, 2018Apprentice
Not sure who you are directing your questions to but as I have stated above - the WiFi distance and channels etc are irrelevant to this problem in my case
Both satellite systems are connected via Cat 5 wired connections
The Satellite dropping connectison applies to @*wired* as well as wireless connections
I agree - for many they may not even be aware of since they are not using network connections that demand a persistent connection. It is far more apparent to me since I am on a wired connection most of the time and I see it drop and disconnect not just the network but my access to my NAS devices and network file storage which I use extensively
I don't doubt that for some it is working but I have clear evidence of this repeated problem that takes down my whole network
What I want is to return the device for a full refund and be done with Orbi. Leave those that have it working and wish them good luck but allow those that it is not working to get their money back and move to something that works for them
The latest per Netgear on all 3 devices - main router and satellites (both connected via backhaul on Cat5):
2.1.4.16
>>>What is the Mfr and model# of the IP modem the Orbi is connected too?Direct to FIOS ONT that works flawlessly
~3,000- 3,500
But again - this is not about WiFi this disconnect and failure occurs on *wired* connections. THe log from the Synology device disconnect is a wired connection
>>>>What is the distance between the router and satellite(s)? 30 feet is recommended in between them, to begin with depending upon building materials.Both satellite devices are connected via backhaul. Base router in the basement, second device ground floor and second satellite first floor
Auto - but I'd settle for a wired connection that was stable
2 low signal and they have been there for several years with prior wifi systems and have never caused any problems. But as above I'd settle to solve the wired disconnects and then worry about WiFi probelms
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I'd go through this if I had a stable wired connection but don't. Unless any of these settings affect the wired connections I'd like o get my wired connections stable and not constantly disconnecting, unless you are telling me that the Orbi Router is unstable for all connections if the WiFi is affected - which would imo be a terrible problem. I've lived with WiFi challenges for years as I am sure many other have and expect them and am lucky to have Cat5 installed to multiple locations to provide reliable service where required - especially connections that need a persistentersistant connection (CItrix fo example)
What am I missing - I've spent says with my network dead, unable to print (hard wired printers not WiFi), unable to access files, security cameras disconnected (hard wired), inaccessible files on NAS devices and connections to the internet that are so slow that any app requiring internet access eventually hangs and has to be manually quit. I've checked the direct ONT FIOS internet which has run consistently >100/100 but that fails to show up wired or wireless
- naerokAug 20, 2018Apprentice
Hey nvt, don't beat yourself over your issues or the unhelpful people in the forums.
I've posted something similar here before but here goes nothing:
there's an issue documented in this post: https://community.netgear.com/t5/Orbi/What-you-can-expect-with-your-Orbi-system/m-p/1503034#M23257 that many people have experienced with no concrete solution.
good luck - so far the only solution seems to be putting a smart outlet / timer on your satellite(s) to reboot them once every 24 hours (I'm not joking) or rolling back the firmware (but I still see people saying they experience the same issues on the older firmware)
see this guy: https://community.netgear.com/t5/Orbi/Orbi-satellite-dropping-connection/m-p/1512445#M24230
I really don't understand the people here that think repeating the same things blindly (have you tried disabling beam forwarding? mimo? how far is the distance between your sattelites? have you tried a factory reset? have you tried spinning in a circle 4 times while holding the orbi above your head and dancing with it? have you tried to balance the satellites on your hands and sing kumbaya while entering your wifi password?) and talk down on the users that experience real issues (especially this furry guy)It's like they have a notepad with things ready to copy/paste blindly to anyone experiencing issues here. I'm not sure if these are bots created by netgear or if these are actual people with too much time on their hands trying to get noticed by netgear to get hired as a customer support employee (it seems like when you call them, this is how they picked their support employees anyways)Again, I appreciate people that are trying to help the community but it really rubs me the wrong way when this is most definitely an issue with the Orbi under certain network conditions and people continuously blame the user setting it up - especially after I've spent several weeks pulling my hair out debugging this issue with no solution (except rebooting satellites multiple times a day) until I replaced the Orbi system completely. - RennceAug 20, 2018GuideHello All,
Thanks for all the replies. Other than not downgrading firmware, I have tweaked all other suggestions and nothing seemed to work until I added a DHCP entry to reserve the IP address of the satellite. This seemed to fix the issue (for both Wi-Fi and wired connection to satellite) and I have not noticed any dropped connection since (ie no hung Citrix session to clients and I sit on Citrix all day). Given I run a business i don’t have time to bugger around with firmware version etc as funny enough I don’t get paid unless I have a working network to connect to my clients.
Cheers Rennce - FURRYe38Aug 20, 2018Guru - Experienced User
Try setting up reserved IP addresses for your satellites and other devices.
Can try this as well:
Heres how I got my friends 50 series up and running:
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highlight/true#M34020Zero issues since setting it up.
If nothing works, you may just have a bad system and would need to be replaced or RMAd.
2.1.4.16
~3,000- 3,500
- nvtAug 21, 2018Apprentice
There is no modem - it is connected directly to the Cat5 out from the Verizon FiOS ONT unit
Both satellites have a fixed reserved IP address and are connected backhaul. Several of my devices have fixed IP addresses but assigning IP addresses is a significant challenge
Both satellites in my configuration are assigned a fixed IP address. I did this when I first set everything up. My problems occurred form the beginning and continue to occur
- FURRYe38Aug 21, 2018Guru - Experienced User
I would try this, since you have a medium sized home, I would turn OFF the 2nd satellite. You may not need it. There maybe too much wifi signal running around. Try just the Orbi router and 1 satellite.
Also try swapping out satellites too. One other users found that one of his satellites was bas while the other worked.
UI would also try just the Orbi by itself while the satellites of OFF. See if the problem continues. If so, you may need a RMA on the whole system.
- nvtAug 21, 2018ApprenticeThanks for the laugh naerok - I needed that!As I've stated - what I want is to be rid of a system that does not work for me. The question I have for NetGear - who have gone radio silent and ignore the support request that I have updated with details documenting the failure and naturally have not called back despite all the promise to do so is thisIs the $750 refund too much to ask - let me walk away quietly, unhappy but not out of pocket vs extremely unhappy customer with a $750 paperweight who wants to make sure this message and experience is heard wide and far by anyone who is considering buying a device that can essentially bring your network to its knees for days..?Latest SpeedTest showing the drop from one moment to the next
I'll try dropping a satellite but in the meantime, my woes are captured perfectly in these connection logs in the attachment showing
10 am 90/90
17:00 7/2
17:42 94/94
17:45 1.5/68
And no surprise radio silence from Netgear with no follow-up calls (promised) and no updates ot my case - in fact, no communication whatsoever
- FURRYe38Aug 22, 2018Guru - Experienced User
I see the test site servers differ too. I would try to use one of the same servers so you can get a better base line. Need to use same servers as other servers could be busier than other thus giving false readings.
Let us know what happens with just using the router alone, then just adding 1 satelilte.
10 am 90/90
17:00 7/2
17:42 94/94
17:45 1.5/68
- nvtAug 22, 2018Apprentice
Sure - there's some variation but not to that extent. If I was able to select the server I would but the service does so based on how busy different servers are so its reasonable to take those values as consistent across two different locations
Either way - I appreciate the help but struggle to comprehend the failure to accept that the system is flawed and broken. Netgear certainly wants to ignore the problem based on my experiences over the last 2 months of misery
If your suggestion of removing both satellites work - then it is clear that the Mesh network technology does not work in the case of the Netgear Orbi system.
You can set specific servers on Speedtest.net. I would use this first.
I'm trying to help you determine maybe if one of the satellites is faulty or your sysems is faulty. There are others that have had good experiences so just because your system isn't working doesn't mean everyone sees the same problem. The MESH systems does work. Just checking here to see by eliminating both satellites first to see if the router works on it's own. If it does, then add a satellite and check again. If the problem appears, swap out the satellite for the other satellite and test. Process of elimiation is all...If the systems is bad, then contact one of the forum moderators and ask them for help in getting an RMA started.
- nvtAug 29, 2018Apprentice
Again - apprecaite your help - not sure who you are FURRYe38 but you are more helpful than Netgear - I just spent 4 hours and 35 mins (8 mins talk time the rest on hold) with the support desk essentially waitign to talk to anyone...literally enyone. I eventuaally hung up.
One fo the saetllites won't sync and shows up as a "device" in the configuration
I've gievn up tryign to get Orbi to work as a router - it does not in my environment and it has killed my home wired network (and wired network) for over 3 months now. As an AP point it might work but again I see the same interimittant disconnects
I don't doubt MESH works - in fact the AmpliFi system that Ubiquiti sent me was up in under 15 minutes and running and working flawlessly for well over a week now.
Netgear support is long past a joke - I have the business class device adn instead of improving support it actually adds further pain and agony. THere is no direct access number for Orbi "Pro/Business" support - you must call the general number and wait a minimum of 20 mins to connect adn validate yoru support case and be transfer. I've asked many times for the direct access number and am told no such number exists - so if you are Pro/Business you are stuck in th sam queue as everyoen else and it just adds an additiona delay and opportunity for failure which Netgear is either knwoengly exploiting or just does not care based onthe hours I have spent being promised calls back and responses - none forthcoming
- FURRYe38Aug 29, 2018Guru - Experienced User
Understand. I too also noticed that working with the Orbi system, even from out of the box, is not a quick setup turn around. I do hope NG will work on this aspect. Ya, it took me close to two hours to get my friends system up and running, and this is with prior knowledge and having to do FW updates before hand and working with wired back haul and its wait for 5 minutes for each satellite. :smileyfrustrated:
Support could use some work and inprovment as well. I wish they were a bit more upfront on contacting them and do a bit more to troubleshoot users problems. :smileyfrustrated:
Sounds like maybe the system you had could have been a bad lemon. There have been others that we have tried to help only in the end to have them get an RMA and the new system seemed to work. So there is that possibility.
Glad you found something that worked. Good Luck and Enjoy. :smileywink:
I'd love an RMA and a return but since they don't answer calls or return calls and I am unable ot create an RMA without talking to someone I can't
Ya, I know. Why I have users contact the forum Moderators on here so they can at least get to someone. :smileywink:
- Retired_MemberAug 29, 2018
I was having the same wifi dropout problem and I posted over a month ago. Knowing Netgear's support, only thing to do is take the unit(s) offline, put your old equipment up and wait months needed for a better firmware. thank you to everyone who has put in the time to bring it to netgear's attention. This was more acceptable when it was a $150 router, but orbi is a serious investment, and I'm sad to see the same responders from netgear's PR forum team ask the same questions, offer the same tips, which don't result in any better results (just a loss of your valuable time). When angry users make a point, they just want you to private message them? the whole point of the forum is so we can ALL get the information quickly, without spending hours on hold. 10 pages of this thread, and the firmware fix hasn't been relased!! epic fail.
Possilbe that your system is just faulty too. Been other having bad experiences and after getting them replaced, the new units work. Something you should ask NG support or contact the forum Moderators about if you haven't already. Not everyone is having bad experiences.
How/Who do I contact?
