Siege7817
Feb 05, 2019Tutor
RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a setting I am missing? This is using wired of course, my wireless speeds are fine. Any suggestions would be great, thanks.
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Has a factory reset of the Orbi router and setup from scratch then go in and immediately test speeds with a wired connection? Don't enable QoS, Access Controls or Traffic Meter or IPv6 on the Orbi?
Might review these:
https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695161/highlight/true#M50762
https://community.netgear.com/t5/Orbi/Download-speed-cut-in-half-on-wired-connection/m-p/1695372/highlight/true#M50815 - ekhalilMaster
Siege7817 wrote:
Hey everyone,
- Do you use wired or wireless backhaul or a combination?
- What other wired devices do you have connected to Orbi?
- Is Daisy Chain enabled or disabled?
- What wireless speeds to do get?
Any progress on this?
Siege7817 wrote:
Hey everyone,
Yes when wired, upload is 750+ but download (which is 1 Gbps) is only 550 mbps.
- alstsmithApprentice
Hi there,
This sounds suspiciously like the issue here ORBI used as Gateway Slower than 1GB Connection
Are you connecting with PPPoE on the Orbi?
That poster mentioned:
"RBK50 to run at 1GBS via ethernet when setup using PPOE and VLAN201. When I test the speeds with ethernet to the centurylink ZyXEL C3000Z,"
Possible same issue, those he never fully completed giving details or updated about his status. I did refer him to NG support.
Hopefully something you can work with NG support to figure out why PPPoE is not up to speed on this protocol.
alstsmith wrote:
Hi there,
