twmd's avatar
twmd
rbr40 dropping internet connectivity
Hello
The system purchased has one rbr40 main unit and two rbw30 satellites (rbk33 is the system name). I have been having dropped internet connectivity with many different settings since I purchased the units over a year ago. For this debug/discussion, I have removed the satellites. I did a factory reset of the rbr40 and loaded the latest firmware 2.3.5.30. The unit still loses internet connectivity a couple of times a day. It does recover without doing a reboot which wasn't true with earlier versions. This typically takes 5-10 minutes. If I force a reboot to the rbr40 internet is back in about 3-4 minutes. Both wifi and wired lose connection.
I have over 25 units/ip addresses connecting including computers using VPN (not orbi's), wireless speakers and home control modules.
Can I enable a log feature that captures when the internet is lost? What settings should I try to change?
thanks in advance
  • twmd's avatar
    twmd
    Aug 03, 2019
    I think this issue is related to the noise on the line back to comcast. It has improved since the changes I made.
    Thanks for everyones input!
  • twmd wrote:
    ......., wireless speakers and home control modules.
    What type of wireless speakers do you have and how are these attached to Orbi, wired or wireless?
      • ekhalil's avatar
        ekhalil
        Master
        twmd wrote:
        speakers are sonos wired system
        How many speakers do you have wired?
        You should not have more than one mesh speaker wired to a router, otherwise you will have loops.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    twmd wrote:
    Hello
    thanks in advance
    • twmd's avatar
      twmd
      To clarify: I have disconnected the satellites.
      this problem occurs even without satellites connected
      arris SB6183
      router
      2500sqft
      n/a
      Auto.  I will try other 2.4g 5g settings
      a few single family homes
      For your remaining questions, can you clarify which might help even though the satellites are disconnected.
      I'll try the different 2.4and 5G channels.
      thanks,
      Tim
  • FURRYe38's avatar
    Let us know if any of the suggestions help.
    Ensure your getting good internet services from the ISP modem.
    Ensure your using a good quality LAN cable between the ISP modem and Orbi RBR. CAT6 is recommended.
    • twmd's avatar
      twmd
      here are the changes I imade based on the suggestions:
      2.4G channel to 1 from auto
      Enabled mimo and beamforming.
      Wmm was already enabled
      Disabled daisy chain
      Fast roaming was already unchecked
      I did NOT Disable 20/40 coexist. this is needed for my intel stick.
      This seems to have helped as I have not been online and had it drop.
      Is there a way to know when the cable modem loses internet connectivity?
      i.e. enable some verbose log file setting?
      I will give an update in a few more days.
      thanks
      • FURRYe38's avatar
        Might check the modem logs when you notice any internet disconnections with the Orbi, the modem maybe loosing access for unknown reasons. Thus Orbi will loose access as well...
  • twmd wrote:
    ......... The unit still loses internet connectivity a couple of times a day. .......
    Does the Router's LED ring turn magenta when this issue happens?
    • twmd's avatar
      twmd
      I will check the led colors on the router at the next drop
