Kris222's avatar
Kris222
RBR50 / RBS50 - No Ethernet backhaul with new firmware
I have a set-up with a router and two satellites with ethernet backhaul.
After a satellite auto-updated to 2.1.4.10 my internet died.
Then I had to do a manual update on Router and other satellite. (Because Orbi doesn’t detect latest version?!?!?)
However, now my Ethernet backhaul doesn’t function anymore. Every time I add ethernet, all network activity dies. No Ip or anything. Just as before Orbi support Ethernet backhaul.
My house is concrete - I have extremely bad reception on the wifi backhaul. Deply disapointing. I have spend hours on this – Please advise
  • Same issue here. I had to make sure Daisy chain was turned on, or I get nothing. Hopefully yours may have been turned off.
    • Kris222's avatar
      Kris222
      Thanks for the help. I’ll try - even tough they are not Daisy chained (star)
      Best,
      • Cmo1's avatar
        Cmo1
        Apprentice
        Yes. Same here. I'm currently only using one wired satellite because my house is only 1700 square feet, but I still had to have that in or it did nothing.
  • FURRYe38's avatar
    Any network switches in the mix? If so, Mfr and model#?
    What is the mfr and model# of the ISP modem the Orbi is connected too?
    What other devices do you have connected to the Orbi router?
    DarrenM
    • Kris222's avatar
      Kris222
      Hi Again.
      Reset didn't work :S
      My ISP modem is Optic from Alcatel Lucent. It's hard fixed by IPS to wall - so I can't check model.
      I also have a simple Sempre unmanaged low power 1G/100/10 8-port switch.
      Please advise.
      Best, Jeppe
    • Kris222's avatar
      Kris222
      And I have:
      - NAS
      - Sonos
      - Philips Hue
      - Logitech Pop
      and about a 1000 iphones and PC's connected as well :)
      • Cmo1's avatar
        Cmo1
        Apprentice
        Try 2.1.4.16 released just last night with a factory reset. I had to make sure Daisy chain was active.
