ZoneMaster
Oct 06, 2017Apprentice
Major Failures After Firmware 2.0.0.74 Upgrade!
ORBI firmware version 2.0.0.74 is failing! I have used the ORBI RBK50 system since Apr 2017. While running the 1.xx.xx firmware, the conection was incredibly reliable & fast. I had max speeds fro...
- Apr 29, 2018
This was fixed eventually. Everything was working fine until the V2.1.4.10 update: now AirPrint isn't working. It would be nice if Netgear could perform some quality control.
ejprosse
Oct 08, 2017Tutor
I’ve had the same issues occurring in the previous version as well. Turning off features to make this $400 unit work is not a solution.
nxc
Oct 09, 2017Apprentice
Exactly. I don't understand why there are so many folks on here intent on defending Netgear with something along the lines of, "Well, mine works." We're all glad it works for you. That doesn't mean many of us aren't experiencing different problems. And disabling feature after feature is not a reasonable suggestion, particularly with a product that effectively forces the user into software updates that can clearly introduce new problems for previously reliable installations.
If you purchased a car that shut off randomly if you were using the stereo and driving over 55, would you accept the suggestion that you simply not use the radio when on the highway? Of course not. We shouldn't be expected to sacrifice basic router functionality to get a working product, particularly when Netgear is selling at the high end of the consumer market and other similarly priced hardware seems perfectly up to the task (Eero comes to mind).
Netgear really needs to get its act together, and we need to start making noise about the problem. I would have returned my RBK50 to the store if I'd known what a headache it was going to be to live with.
