BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jul 17, 2018Guru - Experienced User
How did it "hose" your LAN? More details please.
How is the system configured and set up? Placement?
Any switches in between the router and satellites?
Was a power OFF of the router and satellites for 1 minute after the FW was updated, then power ON the router and let it come to ready then power ON the satellites 1 at a time performed?
Last resort, try a full factory erase on the router and satellites then set up from scratch. Others reported that this helped them:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1548414/highlight/true#M27868
https://community.netgear.com/t5/Orbi/speed-slows-down-Orbi/m-p/1551822/highlight/true#M28289
https://community.netgear.com/t5/Orbi/Is-2-1-3-4-in-auto-update/m-p/1553979/highlight/true#M28616
https://community.netgear.com/t5/Orbi/Orbi-Satellite-RBS50-Not-Connecting-via-Ethernet/m-p/1556692/highlight/false#M28949
ds-will wrote:
This firmware hosed my LAN. Please fix.
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-stopped-my-LAN/td-p/1594578
ds-will
Jul 17, 2018Guide
I posted a link to more details. Here it is again: https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-stopped-my-LAN/td-p/1594578
- FURRYe38Jul 17, 2018Guru - Experienced User
That links to a different user. Please make a new post and share the details of your problem.
- SDplinkerJul 17, 2018Guide
Thanks for the replies! My "unmanaged switch" is my old router with the wifi turned off. Semi-managed switch?? LOL. Maybe there is still enough going on to cause problem. Regardless I plan to get an unmanaged 8 port becuase i'm maxed anyway. Just wanted to try out what I had. Appreciate the links to order of operations - will have a go.
Thanks
Casey
Let us know how it goes when you get the non managed switch in.
Good Luck.
Thanks
Casey
- ds-willJul 17, 2018Guide
FURRYe38 Sorry, somehow got a different one on my clipboard. Here's my actual one, that's listed on my profile as well:
