Endorphine71's avatar
Endorphine71
Apprentice
Sep 25, 2016
Ring Door Bell
Just setup my Orbi system and didn't haven any trouble with over 15 different devices, except my Ring Door Bell.
No matter what I do it won't connect to the Internet.  It connects to Wifi and gets an IP address some of the time, but then will time out and say it cannot connect to the Internet.
Anyone else have a similar problem?
  • Solution: Hi I have just spent the day troubleshooting Ring and Orbi and have found out the following.
    If your Orbi is set to a 2.4ghz wireless channel over 11 the Ring doorbell will not see your wifi. As the wireless channel is auto selected this would explain why some users have no problem and other users cannot connect.
    Disabling/enable mu-mimo and beamform will sometimes cause a channel change hence why it helps some users. But it is nothing to do with the problem and can be left on or off.
    So if you want your Ring doorbell to work select a wireless channel below 11 in your Orbi wifi conf.
    • Curlypaws's avatar
      Curlypaws
      Thanks very much Liteczar - that solves my problem with both the Ring Chime and Ring Chime Pro, as well as my Evernote Scansnap Scanner which wouldn't work wirelessly for the same reason.
    • Endorphine71's avatar
      Endorphine71
      Apprentice
      Glad to hear you got your issue fixed.
      Back when I had my Orbi, even changing the channels did nothing.  Of course the Ring didn't have any way to change the channel or do any basic troubleshooting at the time.  They have since fixed this, probably somewhat due to my complaints on how bad the wifi setup was.  There wasn't a manual way to change anything, you had to remove the Ring from your account and it back again to go through the setup process.  Then on top of that, they double charged me for the $30 year cloud storage.  It was a mess.
      I returned the Orbi within 30 days and got an Amplifi HD, which has worked flawlessly since I have had it.  Only difficult thing is upgrading the firmware, which takes around 3 mins, with the push of a button on the router or app.  I know the speed on the Orbi is faster, just with device compatiblity and support with Netgear was better.
      Who knows, maybe the Orbi2 will have all the bugs worked out.
  • I found using a guest network on the orbi just for the ring created a more reliable connection to the ring doorbell. Prev already disabled beamforming and mu-mimo without an improvement.I was having problems with live view prior to this
  • In order to do this I didn't reconfigure the ring rather I just swap the names of the main network and guest Wi-Fi network is as much to configure the rest of devices than take down ring again
  • I was having problems with getting a picture with my Ring Doorbell. In live view it would just have a circle spin and picture would never load. I would get notifications that someone was at the door and the recordings would be just sound with no image. Ring sent out a new doorbell because there was a hardware problem but now it appears it's unrelated because I continue to have same problem. I just DMZ'd the doorbell and have had zero problems since doing so. It's the first time in months it has worked this good. Anyone have setup instructions for opening ports on the Orbi for Ring so I can take it out of DMZ?
      Endorphine71
      Apprentice
      It is here on their webpage:  https://support.ring.com/hc/en-us/articles/205385394-What-Ports-Do-I-Need-to-Open-in-My-Firewall-for-Ring-Doorbells-and-Chimes-
      If you are faced with a black screen when viewing video and live events in the Ring app, the problem may be related to port settings on your router. In business environments and certain home environments, incorrect port settings can cause device setup to fail as well.
      Internet-connected devices, such as Ring products, communicate with the internet by sending information through ports. Ports are designated openings between an internal home or business network and the outside internet. Each internet service sends data through specific ports. For example, Port 80 is used for website traffic.
      Ring uses the following ports:
      TCP 80
      TCP 443
      TCP & UDP 15063
      UDP range between 16500-32768
      UDP 51504/51506
      Ports can be “opened” or “closed” on your router’s firewall. Open ports allow devices to send information through them, while closed ports block all traffic.  Ring products only function properly if the required ports are open outbound from your router. The process to open ports can be different, depending on your type of router. Consult your router’s user manual for instructions on how to open ports.
      Ring Chime also requires certain ports. If your Chime is not ringing, ensure that the following ports are open outbound as well:
      TCP 80
      TCP 443
      TCP 9998
      TCP 9999
      The client applications also use the following outbound ports:
      TCP 7078
      TCP 9078
      Ring devices and applications do not require any ports open inbound from the Internet on your router.
      • rhester72's avatar
        rhester72
        Virtuoso
        Endorphine71:
        It's worth noting that the ports listed are required *outbound* ports, not inbound.  Ring doesn't need holes poked in the inbound firewall, and thus I've no explanation why his only works in DMZ, unless it's a routing issue.
        Rodney
      rhester72
      Virtuoso
      Must be dumb luck, because Ring doesn't require any port forwarding whatsoever.  It establishes its connection outbound and uses push for notifications.
      Rodney
  • Yeah I don't know. I tjust ook it out of DMZ and rebooted Orbi. Ring went back to not showing video. DMZ'd it again and it's back to working.
  • Endorphine71, I saw that and I what I was getting at was how to set the Orbi router up for that. In all my years of dealing with routers, PC games, PS 2-3-4, etc, I've never once had to port forward or port trigger. I DMZd my PS4 for open nat but that's it. I don't want to get in there and mess things up when I don't know what I'm doing. Kinda looking for a specific guide for this exact Ring/Orbi setup per your post.
  • I was having issues with one of my ring doorbells. One day it went offline and couldn't get it connected, it always failed at some point.
    I finally got it connected again today, the only differences this time around...
    1. Did a hard reset in the ring doorbell; Press and hold orange button for 15 seconds
    2. Put my iphone in airplane mode while doing the set up; according to ring support info, the cellular signal sometimes interferes.
    My orbi is currently set up as default settings wise (outside of changing ssid and wifi password) since my whole fiasco after the latest firmware install.
