computersteve's avatar
computersteve
Apprentice
May 10, 2020
Ring Live Stream Doesn't Work With Orbi
I have tried everything to get the Orbi to work correctly with Ring doorbell live stream. I tried the latest firmware / downgrading / installing the custom firmware from Voxel. I then tried everthing listed in https://community.netgear.com/t5/Orbi/Best-Performance-for-Ring-Devices-Orbi-Config-Settings/m-p/1769017 .. Nothing.. You always get a problem with the live stream. My Echo shows never display when someone rings the doorbell. I found a fix but it requires you buy additional hardware such as the Ring Pro Chime Wifi Extender. netgear please fix this problem.. Thousand of people use the Ring Door Bell & right now the orbi doesn't fuction with it correctly.
  • CrimpOn's avatar
    CrimpOn
    I noticed that it has been several hours and no one has posted a response.  Perhaps a "silly question", but does the Ring doorbell function correctly with the Ring app?  And, this is a "powered" Ring device, correct? (not battery)
    • computersteve's avatar
      computersteve
      Apprentice
      Yes. It works fine only the Orbi doesn’t work correctly with it. If I use my isps WiFi it works but I disabled that cause I really only wanted to use my Orbi in AP mode.
      • CrimpOn's avatar
        CrimpOn
        Sorry I wasn't clear. Ring has an "app", correct? And in addition to the Echo, the camera app also fails?
  • I have 3 Ring Pro doorbells all of which work perfectly with my Orbi in AP mode.
    Might be worth checking the RSSI for each device. Mine currently are -37, -48 and -49 and work really well.
    Also does the Rapid Ring app give the same problems ?
      computersteve
      Apprentice
      The ring pro is a dual band ring product. This might be why you aren’t seeing a problem. My ring devices are gen 1 only 2.4ghz.
      • Bing-Stroller's avatar
        Bing-Stroller
        Luminary
        OK, I now appreciate the lack of dual band.
        Do the gen 1 report RSSI ?
        Any joy with Rapid Ring ?
  • This might work... it sounds assinine, but it really worked for me...I'm looking at my live stream right now and it took about 2 seconds.
    ***1) Turn off ONE of the motion zones on the Ring Doorbell 2 (that's what I have, I can not confirm if it will work with other Ring doorbells).
    This lone change in the Ring setting seems to have fixed my live stream. Yes, I have read on this forum for the past 2 years; I've tried setting up an AP; I've moved my router (RBR) closest to the Ring Doorbell 2; I've followed so many tutorials (found in these forums) changing this and that in my Orbi router. NOTHING worked. Just yesterday, I was reading another random forum and ONE person mentioned how turning off ONE motion zone did the trick for him, I figured what do I have to lose? It has now been 24 hours since I made the change, and I can still access my live view within 2 seconds, CONSISTENTLY.
    2) Other settings I followed from other people's suggestions (but am not sure if it contributed to my success...knock on wood it will remain successful), but I have tried these before to no avial on their own, but I still have them in place WITH turning off just one motion zone in my Ring Doorbell 2 setting:
    - I am on channel 6 on my 2.4ghz
    - I have disabled WMM on both bands
    - I have disabled MU-MIMO
    - I have diabled fast roaming
    - I have an SSID and the password with just letters and numbers (no symbols etc...)
    - My Orbi Satellite has a static IP
    - My Ring Doorbell 2 has a static IP
    3) My Ring Doorbell 2 is about 2 meters away from my satellite, and the Ring Doorbell 2 is connected to my satellite.
    I had just recently purchased AND returned the Ring Pro b/c of the ongoing issue of not getting live stream to work consistently. The "wired" factor didn't solve my issues when trying the Ring Pro.
    I hope this helps you/anyone.
      computersteve
      Apprentice
      The only thing that worked for me was to not use the orbi & setup a router in AP mode / connect the ring devices to that. They load instantly & I don't have to disable a motion zone. I'm glad that helped you. I hope that eventually Netgear fixes this problem.
      • Mstrbig's avatar
        Mstrbig
        Master
        That pretty much tells me your Ring still has the IP address assigned to it from the other router. You may have to reset the ring and re-configure it to grab an IP address from the Orbi DHCP server.
    • Alstar2288's avatar
      Alstar2288
      Tutor
      EDIT:
      I've noticed a direct correlation between the motion zone setting and time it takes to activate live view.
      - when motion zone is set at a minumum distance/deactivated, I can access live view in about 2 seconds, consistently.
      - when motion zone distance increased, it took me longer to access live view
      - when motion zone was set a maximum distance, very rarely was I able to access live view. I had to keep reconnecting until finally, after multiple attempts, I can access live view.
        computersteve
        Apprentice
        So just an update... I was successful getting live stream to work using additional third party access points. The ones I originally used are the Apple Airport routers in bridge mode. The issue with this was congestion. I needed 2 additional networks on top of my orbi / ISPs wifi. So now I decided to just use my ISPs built in wifi. Doing this, It works near instantly. When connected to the RBR50 or RBS50 the live stream just stops working correctly. It works sometimes / then you try again it doesn't work. My ring devices are GEN 1 only 2.4ghz not dualband doorbells. I have three of them. So now I have my Altice Wifi (ISP) for just the Ring devices since you cant disable wifi on there gateway anyway. I wish that netgear & Ring would get together to fix this problem. Its rediculous that you need aditional hardware to get a security doorbell camera to work with the Orbi system. This has caused me to not recommend the orbi system to my family & friends. I have tried all those tricks of disabling motion zones / just naming my SSID & password numbers & letter / Disabling / Renabling MU-MIMO / Fast Roaming / Implicit Beamforming.. The best thing that issued the most successful start of a livestream was disabling WMM on the 2.4ghz band. Problem with this is it locks the 2.4ghz band to 54mpbs. Even doing this the livestream was still hit or miss.
