DrKevorkian94's avatar
Jul 26, 2019
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found.
For instnce:
admin@CBR40:# config get wl_ssid
/bin/ash: config: not found
Additionaly i realized when I log in as admin my name in the promt is admin not root. Im on Mac OS running telnet though terminal. Any ideas why this is the case?
  • CrimpOn's avatar
    CrimpOn
    For instnce:
    I guess you are trying the steps outlined in this post: https://community.netgear.com/t5/Orbi/How-to-disable-WiFi-on-the-Orbi-Router-or-Satellite/td-p/1677533  (read all the way through.  there are corrections)
    The credentials needed are still "admin" for the user ID and the administrative password.  Interesting that your Orbi has a linux prompt of "#admin@", while my RBR50 shows a prompt of "root@".
    I just typed the command on my Orbi and got my SSID.  Did you type config get "w" lowercase L, underscore, "ssid"?
    • I 100% have it correct "config wl_ssid" as you have stated. I keep gettign the error "/bin/ash: config: not found." I have looked though that post and those commadns also deliver the same error.
      • CrimpOn's avatar
        CrimpOn
        Well now, this is just strange.  Just to be onery, I logged in this time as "root" instead of "admin". TOOK IT!  Here's proof:
        =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.07.26 22:29:38 =~=~=~=~=~=~=~=~=~=~=~=
        ====================LOGIN=========================
        Please enter account and password!!
        RBR50 login: root
        Password:
        BusyBox v1.24.1 (2019-06-28 21:18:41 CST) built-in shell (ash)
        Enter 'help' for a list of built-in commands.
             MM            NM          MMMMMMM M M
           $MMMMM        MMMMM MMMMMMMMMMM MMM MMM
          MMMMMMMM     MM MMMMM. MMMMM:MMMMMM: MMMM MMMMM
        MMMM= MMMMMM  MMM   MMMM MMMMM MMMM MMMMMM MMMM MMMMM'
        MMMM=  MMMMM MMMM        MM MMMMM MMMM MMMM MMMMNMMMMM
        MMMM=   MMMM  MMMMM      MMMMM MMMM MMMM MMMMMMMM
        MMMM=   MMMM   MMMMMM    MMMMM MMMM MMMM MMMMMMMMM
        MMMM=   MMMM    MMMMM,   NMMMMMMMM MMMM MMMM MMMMMMMMMMM
        (This is the OS/DK logo.  Don't know why Notepad took all the
         extra spaces out)
        MMMM$ ,MMMMM  MMMMM MMMM MMM MMMM MMMMM MMMM MMMM
          MMMMMMM:      MMMMMMM M MMMMMMMMMMMM MMMMMMM MMMMMMM
            MMMMMM       MMMMN M MMMMMMMMM MMMM MMMM
             MMMM          M               MMMMMMM M M
               M
        For those about to rock... (Chaos Calmer, r6043)
        root@RBR50:/#
        And, I do not get "/bin/ash: <command> not found"
        What I get is "-ash: <command>: not found
        It had NEVER occured to me that the RBR50 and RBR40 would have a different shell.
        Wow!
  • CrimpOn's avatar
    CrimpOn
    Is there anything else 'different' about when you log in? For example, the first thing I see is this:
    And, my prompt comes up as "root@RBR50#"
    Like, even "help" doesn't work?
    • Help does not work. This is my login:
      • CrimpOn's avatar
        CrimpOn
        Wow, am I slow.  CBR40, as in "built-in cable modem" Orbi.  (The only model with one)  And, you've probably had it more than 90 days, so Netgear support won't answer even a simple question.
