lifeandmylens
Dec 17, 2019Tutor
Throughput Tests While Roaming
Please see attached. It was a real world test as I had two Apple TV's streaming YouTubeTV while doing this test, and wife browsing web pages. The test device was an iPhone 11 Pro Max with wifi sweet spots as the app and 10 seconds average measurement in each spot.
I have:
A 6500 sq ft house.
ATT fiber 1gbps service
A BGW210 Modem/Router
1 RBR50 in AP Mode
3 RBS50's all hardwired via Cat5e, 40-50 feet in between units.
Settings:
CTS/RTS Threshold (1-2347) 2347
Enable WMM (Wi-Fi multimedia) settings - enabled
Enable 20/40 MHz Coexistence - enabled
2.4 Transmit Power Control - 75%
5 Transmit Power Control - 100%
Enable MU-MIMO - enabled
Enable Daisy-Chain Topology - off
Enable Fast Roaming - on
Enable Implicit BEAMFORMING - off
Running V2.3.5.30, after a clean reset and setup again.
Would love some input on these numbers and Orbi's lack of ability to roam and maintain throughput with mulitple streams. And any suggestion changes I could make to improve things.
My experience has been that my Android smartphone and tablet took about 2 minutes to "Fast Roam" from router to satellite (and back). (Apparently two minutes is "fast". I did not experiment with Fast Roaming off.)
How long did you remain in one location before moving to the next location?
Thanks. About 30-45 seconds in each room.
- Ragar99Luminary
What version of the Router do you have, v1 or v2? Or does the Orbi router have a usb port on back?
Your numbers are pretty poor, I'd back up and test with nothing else running or streaming.
CrimpOn wrote:My experience has been that my Android smartphone and tablet took about 2 minutes to "Fast Roam" from router to satellite (and back). (Apparently two minutes is "fast". I did not experiment with Fast Roaming off.)
There was not a lot of science in my Fast Roaming experiment. I opened the Orbi web interface and brought up "Attached Devices" on my Android tablet. Saw that I was attached to the router. Went downstairs and sat by the satellite watching the Attached Devices display update. Eventually, it said I was attached to the satellite. Maybe the actual time it takes to switch is less than two minutes. What I was trying to verify at the time is that devices actually do switch back and forth. And, at least some of them do.
- Thanks all. I’m evaluating my placement to see if that’s affecting it. Does anyone have any recommendations on signal strength of the router on where to place the satellite (especially if hardwired)? Place it at -60, -75, -85 etc?
Also is it generally better practice to leave power levels of 5G alone or lower the power levels down and place additional satellites?
What happpens with Beamforming enabled?
V2.5.1.8 is now avaialable FYI.
lifeandmylens wrote:Please see attached. It was a real world test as I had two Apple TV's streaming YouTubeTV while doing this test, and wife browsing web pages. The test device was an iPhone 11 Pro Max with wifi sweet spots as the app and 10 seconds average measurement in each spot.
I have:
A 6500 sq ft house.
1 RBR50 in AP Mode
Settings:
FURRYe38 wrote:What happpens with Beamforming enabled?
Thanks, I am updating now to the new firmware and will test again. I am happy to try beamforming, but I believe implicit is for order devices, and explicit is enabled by default.
Order devices?
You might try both enabled and disabled to compare results.
