NikMan
Dec 06, 2018Aspirant
Using Orbi as AP with managed switch
Hi All,
I'd be grateful for any advice! I just bought an Orbi with 2 satellites as my (three) old Netgear PoE WAP's have been playing up recently. My set-up is-
1. Virgin media Superhub 3 in modem mode, connected to -
2. Netgear Nighthawk R7000p, acting as my router, plugged into -
3. Netgear 48-port managed switch and patch panel.
All of this kit is in the basement - and the wifi doesn't reach the ground floor hence the WAP's on each storey.
I managed to get the Orbi base station set-up as an AP by plugging it directly into the router. However, since I moved it to the ground floor and plugged it into an ethernet port, and patched that to the switch, it won't get an IP address from the Router anymore so no internet. I haven't set-up the satellites yet - I was hoping to do this after getting the AP working on the ground floor.
Please can anyone advise on where I might be going wrong? Are there any special settings I need to use on the Orbi router to get it working with the managed switch?
Thanks in advance!
NikM
Hi All,
I've managed to get the Orbi working with my switch etc. I don't if I this was entirely necessary but what I did was -
1. changed Orbi back to router mode
2. Synced both satellites
3. Changed Orbi router back to AP
4. Plugged it into the LAN port and waited a while!
I think the original LAN port I was using was faulty, which clearly caused a lot of my original confusion/problems.
It all seems to be working now, with my Netgear R7000p acting as Router. I have one of the Satellites also connected to the switch via a LAN port as well - which I am assuming will help the stability of my MESH network? I am still trying to understand some of the new terms associated with MESH WiFi (ethernet backhaul/daisy-chaining etc) - when I logged into the Orbi it said my backhaul was good?
However! Just discovered this morning that one of my Sonos boxes can't connect to the Orbi satellite WiFi. I did a quick Google and discovered lots of people have had similar problems. I am going to have a play and try and get it working - if not then I will have to connect the Sonos boxes use a LAN connection.
Thanks for all the help/advice!
NikM
p.s. - I did log into my Netgear Switch, and I think the "IGMP protocols" were already disabled?
What is the mfr and model of the managed switch. Others have said to disable IGMP protocols on the managed switch to get it working with Orbi systems.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M38123
Green Switch: https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highlight/true#M43817
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/highlight/false#M44394What FW is currently loaded?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Daisy Chain needs to be disabled for wired back haul connected satellite(s).
- st_shawMaster
I use Orbi in AP mode with managed switches from Ubiquiti. No issues.
There is no setting in Orbi that I can think of that would prevent this from working (assuming nothing is set incorrectly.)
First, check to make sure things are wired correctly and there are no bad cables. Plugging a laptop or other device into the port being used for Orbi could help diagnose this. Then, double check to make sure Orbi is really configured in AP mode. Also, make sure Orbi's AP mode is configured to get an IP via DHCP and not using an IP hardwired in the Orbi web UI.
