Yorkshirepud00's avatar
Dec 17, 2019
WI FI frequency
HI could some help i am trying to set up my home with wi fi switches and they only work on the 2.3GHz how fo i split the SSID so i can pick this because they dont work on 5GHz
Thanks advance for any help
Lee
  • FURRYe38's avatar
    What is the Mfr and model of these "WiFi switches"?
    There a link to there web site support page?
    Orbi doesn't allow to separate the SSID names officially on Orbi. However you can do this:
    https://community.netgear.com/t5/Orbi/v2-5-0-38-undoes-SSD-split-is-there-a-fix/m-p/1816546/highlight/true#M73951
    Once you turn OFF The 5Ghz SSID broadcast, you should be able to setup the 2.4Ghz devices on Orbi.
    Lee
  • CrimpOn's avatar
    CrimpOn
    First, make certain that there is actually a problem.  Manufacturers emphasize (in LARGE TYPE) "Requires 2.4G Network.  Does not work on 5G!!!" and people panic.  Well, Orbi (and all of the other modern mesh routers) provide both 2.4G and 5G networks.  So, you have a 2.4G network, just what the device needs.  Chances are that when you go to set up the device, it will discover the Orbi network and be fine.  My five brands of smart plug and several brands of video cameras did.
    For those rare instances where the smartphone setup program fails, the simple remedy is to use the Orbi web interface to temporarily stop broadcasting the 5G SSID.  Tell the smartphone to "forget" the Orbi network and then join it again (at 2.4G).  After the device is set up, go back to the web interface and resume broadcasting the 5G SSID.
    • Yorkshirepud00's avatar
      Yorkshirepud00
      I have tried what you said but it did not work i even checked that the router was on the 2.4 by looking it up on my Laptop do you think it colld be a switch faulty, could i ask you what make you have installed to yours its a light switch i have bought a Sonof
      I want to go wireless on all the switchies in the house but just thought i would buy one to see what its all about and how they work,
      whats your thoughts
      • michaelkenward's avatar
        michaelkenward
        I have tried what you said but it did not work i even checked that the router was on the 2.4 by looking it up on my Laptop ...
        What do you mean by that?
        It is not clear from your message that you turned off the 5 GHz SSID broadcast.
