dennypage
May 31, 2025Initiate
LM1200-111NAS firmware
Hello,
How can I get a firmware update for the LM1200-111NAS?
Attempting to check for firmware update via the admin page gives:
Update Error
There was a problem updating your device. Please try again later.
Attempting to install via file with firmware downloaded from the support site,
https://www.downloads.netgear.com/files/GDC/LM1200/LM1200_20.06.09.00_LTE_upgrade_package(US).zip
indicates that the firmware is not compatible with the device.
Thanks.
- thetitanAspirant
andyminr Could you please provide download link to the file Netgear support supplied.
Per my explanation in another thread, the official download page (updated in 2025) indicates that the file we get for LM1200 is not compatible with LM1200-111NAS, and the SPK file was last updated on 02-01-2022. So, while uploading the file myself is successful, I still get the error message that the firmware itself is incompatible.
Thank you.
- BMFMAspirant
Hi, Can you share the 111NAS firmware upgrade? I have the same problem
- WebFeetTutor
Thank you. It worked for me. I will cancel my support case.
- andyminrTutor
NETGEAR recently released an LTE update for the LM1200-111NAS modem. I downloaded the file, unzipped it and with a Ethernet cable uploaded the file to the modem. Upload was successful. Modem seems more reliable and stable.
NETGEAR support was most helpful working with me to provide an update to the original release.
- WebFeetTutor
I have the same problem. Hard to believe there is no solution to providing an advertised feature (failover).
- andyminrTutor
Same problem. I bought the LM1200-111NAS directly from Netgear on May 21, 2025. I haven’t been able to update either online or by the suggested file. I have a case open with Netgear to see if they can provide a solution. Modem works with Verizon when there is a good signal. Not completely reliable as it will drop out whenever.
I would like to be able update the software to take advantage of fixes and improvements. This is what is done for most if not all of the software and firmware.
- wcoolnetAspirant
How did you manage to open a case with Netgear? When I tried to open a support request online it wouldn't recognize the device serial number, so wouldn't let me proceed with opening a support request.
- andyminrTutor
Initially Netgear didn’t recognize the S/N of the LM1200. I contacted them by phone to open a case. With an open case i sent screen shots of the labeling on the modem and box. Netgear support was able to register the modem.
- wcoolnetAspirant
I'm having the same problem. I also have a LM1200-111NAS
Below is from my about.txt output
Firmware Firmware Version: EC25AFFDR07A09M4G Firmware Build Date: Unknown App Version: NTG9X07C_20.04.07.06 Web App Version: LM1200-HDATA_03.03.103.189 Hardware Version: 1.0 PRI Version: 23115115, 03.00
