K4r0lSz's avatar
K4r0lSz
MH7150-100EUS (M7) – Has anyone successfully activated a carrier eSIM? (Plus Poland / Europe)
Hello everyone,
I am trying to activate a Plus Poland (Plus na Kartę) eSIM on my NETGEAR Nighthawk M7 (MH7150-100EUS).
Router information
  • Model: MH7150-100EUS
  • Software Version: 2.12
  • Purchased in Poland
What happens
  • The QR code is recognized correctly.
  • The eSIM profile starts downloading.
  • The installation reaches the final step ("Finishing").
  • The router then displays Error Code: 1 and the eSIM is not installed.
The eSIM profile is brand new and has never been activated on any other device.
I have already:
  • restarted the router,
  • confirmed that the router has Internet access,
  • checked for firmware updates (none available).
I have also opened a support case with NETGEAR.
My questions:
  1. Has anyone successfully activated a carrier-issued eSIM (not a NETGEAR marketplace eSIM) on the MH7150?
  2. If yes:
    • Which mobile operator?
    • Which country?
    • Which firmware version?
  3. Has anyone successfully used Plus Poland, Orange Poland, Play or T-Mobile Poland eSIM on this router?
  4. Does anyone know what Error Code 1 at the "Finishing" stage actually means?
I have found a few discussions where users experienced similar eSIM activation issues, but I have not yet found any confirmed successful activation with a Polish carrier.
Any information would be greatly appreciated.
Thank you!
  • Update (after NETGEAR Support recommendations):
    I would like to share an update in case it helps other MH7150 users.
    Following NETGEAR Support recommendations, I performed:
    • Full factory reset
    • Fresh router configuration (no backup restored)
    • New carrier-issued eSIM generated by Plus Poland
    • Internet connectivity confirmed
    • Latest available firmware (2.12)
    • OTA reports no newer firmware available
    The behaviour remains reproducible.
    The router:
    • successfully reads the QR code,
    • contacts the SM-DP+ server,
    • starts downloading the eSIM profile,
    • reaches the final installation stage,
    • then fails.
    Originally the router reported Error Code 1.
    After generating a completely new eSIM profile from the carrier and repeating the test after the factory reset, the router now reports Error Code 15.
    Both eSIM QR codes use the same SM-DP+ server:
    pkt.prod.ondemandconnectivity.com
    NETGEAR Support has been informed and I have requested escalation to the firmware/eSIM engineering team.
    If anyone has successfully activated a carrier-issued eSIM (not NETGEAR Marketplace eSIM) on the MH7150, I would really appreciate knowing:
    • firmware version
    • country
    • mobile operator
    • whether activation was done via QR code
    Thank you.
    Even a confirmation that a carrier-issued eSIM works on your MH7150 would be very valuable.
    • K4r0lSz's avatar
      K4r0lSz
      Update
      I have some important new findings.
      After further testing:
      ✅ Orange Flex eSIM installs and activates successfully on the same MH7150 (firmware 2.12).
      ✅ The Orange Flex eSIM remains fully functional after reboot.
      ✅ The same Plus Poland eSIM profile installs and works correctly on a Xiaomi smartphone.
      ❌ Plus Poland eSIM still fails only on the MH7150 with Error Code 15 during the final installation stage.
      This suggests that:
      the MH7150 eSIM functionality is operational,
      the Plus eSIM profile itself is valid,
      the issue appears to be specific to the interoperability between the MH7150 firmware and Plus Poland eSIM profiles.
      NETGEAR Support has now escalated my case to the Level 2 team.
      If anyone has successfully used a Plus Poland eSIM on the MH7150, I would really appreciate hearing about your experience.
      • Fortra's avatar
        Fortra
        Luminary
        K4r0lSz​,
        At some point they will get to the bottom of your issue with a OTA update for your mobile router device.
        Your doing well in doing your own internal testing and releasing your own findings and experiences you've posted above!
    • K4r0lSz's avatar
      K4r0lSz
      Update – new Plus eSIM tested on firmware 02.24
      Another test has now been completed using a newly issued Plus Poland eSIM profile on the MH7150 running the new firmware 02.24.
      Unfortunately, the problem is still reproducible.
      The test was performed after restarting both the MH7150 and the phone. The activation failed again, and I submitted a new Instabug report immediately after reproducing the issue, including a short screen recording of the complete activation attempt.
  • I have a similar issue in France with Lebara.fr. It is impossible to activate the card because Lebara sends an SMS after the card is initialized to complete the process, but the message is never received on the M7's end (nothing shows in the web interface). Lebara is not very helpful in finding solutions either.
    In the end, I used the Nomad eSIM (the Nomad app on iPhone), and it works well. But it is not as cheap as Lebara. I am also using firmware 2.12. Overall, I've found eSIM activation to be hit-or-miss, which is a shame because I bought the M7 for eSIM support.
    • K4r0lSz's avatar
      K4r0lSz
      Thank you for sharing your experience.
      Out of curiosity, do you know which SM-DP+ server your Lebara eSIM uses?
      It can be decoded by AI from QR code, if it's not written directly, when carrier provide eSIM.
  • Hello! I have some similar problems with Wind3 italian operator. After having a couple of time the error, the esim is actually installed and activated.
    However, the device fails to unblock the sim: when i try to insert the eSIM pin, it sais that is wrong and still give me 3 attempts. No support from anybody.
    I'm stuck. I think I will ask for a refound of the device and of the eSIM at this point.
  • I had a similar issue with eSIM provisioning failing at the finishing stage on mobile routers—it usually happens due to profile encoding or SMS verification requirements that the router firmware can't process properly (Orange Flex seems to be one of the few using a broader compatible profile format). Until NETGEAR pushes a fix for SM-DP+ interoperability, travel eSIMs like Nomad or using a physical nano-SIM remain the safest workarounds.
    On a separate note, if anyone here is setting up fleet management or needs commercial tracking solutions in the UAE, GPSCompany.ae providing SIRA/RTA-compliant GPS units and real-time telematics.
    • K4r0lSz's avatar
      K4r0lSz
      Yes, the best workaround for this moment is to use physical nano-SIM from Carrier, as looks like not for all (or most popular) provisioning is working as should.
      It might be a trouble, if You have HW (Mobile Router) that is capable for 6 eSIMs and 1 physical, but need to replace that one every travel, cause SW issue reduce functionality.
      Hopefully I would be helpful for Technical Support, so they can manage to fix it ;)
