I_Must_Know
Aug 28, 2026Tutor
Netgear Mobile App blocked notifications
Hello everyone.
I've been unable to find a solution to this issue.
It's weird enough that Android has this app under System apps.
But the OS will not allow notifications from the Mobile App "All notifications from this app are blocked".
When I go to App notification and switch the enable button, the OS disables it again.
The android os is version 13.
Has anyone here found a solution?
Thank you.
How is this MR6150 deployed? Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
And, if it is mobile, I would think it should be within reach.
- kevinthrone594Aspirant
Yeah, the missing notification options would make me suspect this is more than a normal Android permission issue. The fact that the toggle turns itself back off, and the app doesn’t even show the usual options in App Info, makes the app/OS compatibility angle seem pretty likely.
The 2024 last-update point is also worth considering. Hopefully someone with an MR6150 can confirm what Netgear currently recommends for Android 16, because using the web interface as a workaround isn’t really the same as having the app notifications working.
- HappyCatVirtuoso
I want battery status(this m6 runs way hotter than the m1), temperature status, firmware status,
I usually keep mine plugged in or just do a quick check on the screen. Only takes a second.
I tried the trouble ticket route. Got a standard reply from the Help Support. But when I gave them the same information I posted here....."crickets" .
I should have just stayed with the M1 hotspot. Even with AT&T raising my grandfather old plan rates.
What are you needing notifications for?
Right?! And it hasn't been updated since 2024.
So to the Netgear support staff, which software are people suppose to use with Model MR6150 ?
If you say "Mobile App" then its obsolete until your development team updates the software for 2026 and beyond.
- HappyCatVirtuoso
And, that brings us back to the reason people visit the Community Forum.
When their 90 days of 'complimentary support' expire, and if they have not purchased a support contract within 120 days of buying the product, then there is no way to contact Netgear support.
Although there appear to be a few Netgear employees who occasionally comment on specific issues, as a general rule, the only people participating in Forum discussions are customers.
- HappyCatVirtuoso
Very strange. Just to "have a look", I attempted to install Netgear Mobile on a Samsung Android phone and a Galaxy tablet, both running Android 16. Neither could find an app called "Netgear Mobile". Not encouraging.
Nighthawk M6
Model MR6150
- HappyCatVirtuoso
It would be really helpful to know which mobile router this is.
All You Need to Know about NETGEAR Insight NETGEAR
This is the video about Insight. If netgear is asking users to do all of this just to get notifications from a M6.........smh
I just installed the Insight app and its nothing like the Mobile app. The Insight app just manages your Netgear account but it doesnt handle the settings within the M6 hotspot like the Mobile App does....or use to.
The only 2 options I have is to install Mobile App and forget about notifications.....or use the weblink.
