Speegs's avatar
Speegs
Star
Mar 14, 2017
Nighthawk M1 battery flat and offline in morning
Hello,
I have a Telstra Nighthawk M1, works pretty well.  Happy with the speeds, the form factor, real ethernet port and on the very infrequent times I use it without power the battery life.
I have a problem with it, I have it charging and plugged in.  It then seems to somehow turn off the usb port overnight.  Run the battery down to zero.  Which is VERY annoying as I need to pull the usb cable, plug it back in.  Wait 15 mins until it has the minimum charge to connect back to Telstra.
Then it does it again overnight.  The unit is getting power the whole time.  Is this unit faulty or is there something I can reconfigure to stop this?
Appreciate any advice, it's on the latest firmware.  In fact I'd like to run it without the battery, is that possible?  I did that on prior netgear units Advanced III and in the netgear cradle and found it worked more reliably.
I'm using the supplied USB C cable to power the device.  The USB wall plug isn't faulty I tested it by charging my iPad with a different cable of course, must be operating well as iPads require plenty of power to charge.
Leigh
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi Speegs,
    Glad to hear your positive feedback on the M1.  I would like to find out more about your charging issue.
    1. How many WiFi devices are connected overnight?
    2. Is there any device also connected over Ethernet overnight?
    3. Do you have a MicroSD or USB thumb drive plugged into the M1 constantly?
    4. Are you plugged directly into the wall socket or using a power board with the supplied wall plug?
    5. How much data is being used over night?
    The M1 can be powered up without a battery but we do not recommend doing this.  You can always give it a try and see if you get better results without the battery.  We do have some charging algorithm in the firmware to prolong the use of the lithium ion battery and charging can stop if the device gets too hot but should start charging again once the temprature drops below the threshold.  If there is constant heavy download occuring then it could cause the battery to drain as the device is most probably getting quite hot overnight and having either a USB thumb drive, MicroSD, Ethernet or all 3 connected would also add to heating up the device.  Keep in mind that this is a mobile router and is not a replacement for a fixed line connection.  If you require constant heavy downloads then try without the battery and see if it makes a difference.
    ArodiD
    • Speegs's avatar
      Speegs
      Star
      Zero
      Yes about 8, doing Windows Updates on hired computers machines and pretty much constantly syncing about 1mbit/s of data back to a central server.
      No.
      Using the supplied 1amp Netgear wall plug.
      About 100GB per night.  I bought it to use it, not to look at the pretty lights.
      So far I've discovered ditching the standard wall plug and plugging into a USB port with 2.4amp capacity made a big improvement.  I'm yet to run it to the point where the battery + power = flat.
      I can't with certainty say the 2.4amp USB supply is the solution, I'll need more time before I can prove that scientificly.  However my gut is telling me the supplied wall plug is NOT powerful enough for regular use.
      I don't get it, why is it only designed to be for intermittent use, I know many customers will use it that way.  However there are also many who can't get good Internet via land facilities and those who need a portable device for event work (all day conferences etc where Internet at from the conference location is EXTREMELY expensive and hard to organise, ie no cables to your assigned area etc).
      Hopefully they consider those who use it as a better ADSL connection or a workhorse for an event when they make the next one and/or future firmware updates.
      For me the unit is an NBN speed portable solution.  I often see speeds of 40mbit - 200mbit down and 20-60mbit up.  I can't get a fibre connection where I need the Internet and I'm not at the location for more than a week.  So it's perfect that way.  Data costs a fair amount, but setup fees for a connection this fast are often several thousand dollars.  So the high price of data is not really an issue it's cheaper than the setup fees for the temporary connections in the long run.  I also take advantage of Telstra ability to "share" data on a business plans.  That softens the blow on a large account with 30+ other mobile devices you can borrow from other people's data for this large events.
      20GB x 30 plans = much data, avoiding excess charges.
      I guess if you call doing 200GB+ in 2 days a heavy user that's how I use this thing.  It's not much data nowdays people get 1TB+ per month on a home plan pretty easily.  Sure it's possibly quite a lot of mobile data, but there will be more of this in the future as prices for mobile data drop so design products around doing 3TB of mobile data a month, that might be the norm by the time the next generation is released.
      • Speegs's avatar
        Speegs
        Star
        Hello,
        Just did a test without a battery.
        The unit reboots when I start transferring some data.  A basic speedtest.net (from 1 wifi computer) is enough to make it reboot.  (That was with a 2.4amp usb wall plug).
        So no battery is not a good solution for those who are trying.  Unless of course my unit is faulty.  It works fine otherwise, just seems to draw more power than it gets.
        Let me know if my unit is faulty I will return it for a new one from Telstra.  I don't want to waste my time if the next one does the same.
        Thanks.
  • Hello now I use m1 24 hours everyday I know this device charging in 43 temperature they will open protect function so when useing charging I suggest not connect lte service and doing download and upload process
  • I have the same issue - looks like a firmware fault to me. I use mine plugged in as it's an ADSL replacement (no NBN or ADSL out where I am). So it stays plugged in all the time. But sure enough.... over night something happens and it's dead in the mornings....
  • Hi,
    I'm having the exact same problem! This is so frustrating, has anyone from Netgear come up with a fix?
    I'm using a relitively small amount of data (approximately 1GB over a whole week) through an ethernet port only. There are no devices connected via wifi and no SD cards or USB drives attached. I am using the supplied wall plug and cable, but have also tried other 1A 5W wall plugs and generic USB 3.0 cables.
    If I charge my phone or laptop overnight (or for a week/month for that matter) I would expect it to be fully charged and running at the end of that time period. How come the Nighthawk M1 had been set to discharge once it is fully charged?
    Has anyone come up with a solution for this? I need to be able to run the unit for an entire week straight, without power failure. I use the Nighthawk routers to provide internet for remote access software, so I have no way of charging the device once it discharges.
    If anyone has any insight, please help!
    Pat
    • Speegs's avatar
      Speegs
      Star
      Hello,
      The only "workaround" I know of is.
      Remove the Battery.
      Get a powerful usb wall adapter such as the ones designed to properly charge an iPad.  Otherwise you will find the unit will reboot when it draws more power than the supplied usb adapter can produce.
      Only insert the battery if/when you are going portable with the device.
      Hope it helps, report back your sucess/failure I've only bought one Nighthawk M1 and stayed on the older Cradle and Advanced III hotspot units where possible due to this problem.  According to Netgear they didn't design it with permanent use in mind, but thought everyone would use it "on the go".
      Telstra and the packaging unfortunately doesn't tell you it's not designed for use beyond 8 hours.  The people selling it as usual have virtually no product knowledge or experience.
      I hope the next edition solves this problem or a firmware update down the track solves it.  I do think you will need a larger power supply even if the firmware is adjusted to remedy long term use.  Luckily they are easily available since iPads have been on the market.
      Leigh
      • Speegs's avatar
        Speegs
        Star
        My first attempt with a 2.4amp power adapter failed, so be sure to try a very powerful usb wall adapter.  I found the real Apple iPad 12Watt one worked, some others made for charging iPads did not seem to supply enough power to prevent rebooting.
  • We have a few of these devices, one that we know about will switch off once a week with the battery completely drained. Have to unplug the power from the device and plug it back in to get it to turn on.
    Just purchased a couple of QuickChage 3.0 30W chargers http://www.comsol.com.au/Products-by-Category/USB-Wall-Chargers/COWCSQ3WH_2 and have removed the battery to see if that improves the situation.
    I wish Telstra had a few more options for 4G gateways.
  • Hi Netgear Support,
    I think I have found the problem with basic steps (not resolved, just found it) but is up to you (Netgear Team) to address the issue on an update.
    It seems that when the hotspot reach a certain temperature it stop charging, but the sutuation is that the temperature "threshold" is very low, maybe 80 F... my face is warmer than that!
    Everyone having this hotspot can do the following to confirm this "theory"of mine. Unplug the battery an put it on the freezer for 2 minutes or when it reach 70 F (it is still a confortable temperature), then put it back into the hotspot and you will see it will start charging, but when it reach a relative warm temperature (80 to 85 deegres, an extremely safe temperature) you will see how the charging bar and indicator on the app stop and the battery begins to drain.
    I thinks theres is a problem on the temperature sensor itself or a the temp threshold programed in the coding that is extremely low causing this problem to all of us from this amazing device.
    Netgear Team, please address this issue soon, don't let this great device dig a hole for his own tomb.
    A fanboy of Netgear Products.
    Thanks.
    • AlbertMartin's avatar
      AlbertMartin
      Guide
      **Update to my previews post (See above this one)
      Instead of taking the battery off the unit, just remove the battery cap (not the battery) and leave it connected to the charger. Then go to the Hot Spot Web Page administration (not the mobile app) and select Settings >> "Carrier" Wi-Fi Status >> Diagnostics and you will see the system and battery temperature. As soon as the Battery reach 40 C (104 F) it automatically stop charging. Now put the hot spot near a fan or AC unit (without disconnecting it from the charger) and as soons as it reach about 37 C (98.6 F) it will automatically start charging again. Keep in mind that 37 C (98.6 F) is the same temperature as the human body... sooooo I don't understand why Netgear team decided to select this temperature (40 C) as a threshold and label it as "danger" when is really a safe temperature and make the unit stop charging... At least I know that the unit is working fine and the problem is in the software.
      Netgear Team, is really easy to fix this problem, please do so soon! This is really anoying!
      Netgear Fan Boy!
  • Removing the batter and putting it back fixed the problem...
    Thanks
    • JasonN's avatar
      JasonN
      NETGEAR Employee Retired
      Hi AlbertMartin,
      Can you please explain how you use your device? Do you normally leave the battery in while using the AC power adapter even though it is at a full charge?
      Please let me know. :]
      - Jason N
      • Hi,
        Always leave the battery on the device. I can't used it pluged in without the battery. When I do that, the device restart every few second and keeps doing it on an endless loop no matter if using the original USB C cable and adapter or using higher quality ones with more watts than the original, it just begins to reboot endlessly. Also happened with my first device, I returned for a new one and also happen the same thing, so my conclusion is that is a problem with the "temperature limit" programmed on the firmware of the device. If I put the unit directly on the supply AC duct it charge flawlessly, but keep in mind that the temperature when the device stop charging under normal conditions is about 37F (similar as a human body temp, relative warm and by far not dangerous).
  • If you believe the power adapter is not capable of charging the device, then try switching off one of the two WIFI modes on the router. This way the power consumption will drop and the power adapter will be enough.
    I hope this helps.
    • JSchnee21's avatar
      JSchnee21
      Virtuoso
      Hi Ayed,
      The issue is that the battery thermal management in the MR1100 is too conservative.  It stops charging due to "overheating" because the "hot" temp threshold is set too low.  This is a known issue with this product.  This product unfortunately was not designed for hot climates (I wonder if the AUS or EUS versions are any better)
      This is a simple software change in firmware that Netgear seams unwilling to change.  General consensus is that Lithium ion batteries are safe to charge up to at least 45C, some would even say 60C.  But the MR1100 stops charging due to thermal sensitivity at like 35-37C.
      Charging slower should help some.  Leaving the case open and/or setting up a small fan also helps.
      Occassionally there are also bad batteries that heat too much while charging.
      • AllianceIT's avatar
        AllianceIT
        Tutor
        AUS version isn't any better. We had a few Nighthawk batterys bulge as well leading to the batteries being removed.
        We have started to replace all our always on Nighthawk devices with mains power devices now that additional devices are available from our carrier.
