DUBJE84's avatar
DUBJE84
Tutor
May 18, 2018
Nighthawk M1 (MR1100-100EUS) - reboot loop when connecting to fast 4G+
Hi, I was looking for a solution of the following issue.
When I am at work and in a 4G area, (30Mbps speed) all works fine.
If I turn on the M1 in an area (at home) )with a faster connection, 4G+(80Mbps), then my M1 goes into a bootloop.
Anyone seen this before and a solution for it?
  • I have seen one boot loop SW bug. It is fixed in the latest beta. Only workaround before beta version was factory reset, if it is continuous boot loop.
    • DUBJE84's avatar
      DUBJE84
      Tutor
      Where can I find the beta firmware?
      the factory defaults didn't fix it for me.
      • TeeJay74's avatar
        TeeJay74
        Virtuoso
        Please try again by pressing that reset button on the backside.
  • I am using an AT&T version of this device.
    I found in areas of low cell signal, device locks onto Band 12 (700Mhz), not reboots.
    When used in areas of good signal, device locks onto Band 2 (1900Mhz), and constantly boots until it will NOT power on until battery is removed and reinserted.  Bad device? or Firmware?  or Both?  Either way, this is the second device I had to return because of reboots - bad showing IMO from Netgear.
  • So this is the reply I received from the "experts" of netgear support:
    "Update from NETGEAR:
    Hello Joey,
    This is regarding your open case with NETGEAR.
    I just received a feedback from our team and the reason why your mobile router is rebooting when connected to the 4G+ network is because it cannot handle this type of connection. The 4G+ is not one of the supported bands for the Mobile router. It supports:
    LTE/4G 1/2/3/4/5/7/12/29/30/66
    3G 2/4/5
    Therefore you can only use 4G with the device and cannot use 4G+ with it.
    I apologize for the inconvenience this has caused you.
    Thank you for your time and patience.
    Again, thank you for choosing NETGEAR.
    Clarisse
    Expert ID: 46194
    NETGEAR Support Expert"
    So they are saying a Cat 16 modem can't handle a Cat 6 connection. I am sending my device back to the retailer for a refund. It's garbage. And the support seems to be of the same quality.
    • winger13's avatar
      winger13
      Guide
      I am laughing so hard right now. Did the engineers not talk to the designers? Did Netgear Support really get that bad? Or did we all get duped buying a device supposedly capable of 100+Mbps download speeds (LOL me included)?
      In all seriousness, I have owned Netgear products for many years. It does seem their overall support (and possibly their product quality) has taken a big dump, literally, in recent years. This is so unfortunate.
      I have an open ticket for the past 2+ months - it's up to level 2 support now , and you wouldn't brought the quality of the support I am experiencing. It is not good.
    • JasonN's avatar
      JasonN
      NETGEAR Employee Retired
      Hi Everyone,
      If you are still having this issue. Can you please PM me the answers to the questions below so I can forward it to my internal team. Thank you :]
      • Are they still having the problem?
      • Contact info?
      • If they contact support and what is their case number
      • What is the FW version they are running?
      • What is the SKU of their MR1100 device?
      • Which battery are they using? W10 or W10a
      • What is the exact issue they are seeing and how often?
      • How easily are they able to reproduce the problem?
      • What do they do to resolve the issue? do they reboot the device, pull the battery reinsert or do something else?
      • How is the device running? Running on battery, plugged into USB of the computer, plugged into the ac power, plugged into AC power no battery inserted?
      • Where is the device being used? In a fixed location or on the go?
      - Jason Nguyen
      • networksman's avatar
        networksman
        Hi
        Was this ever resolved? I am looking at buying this exact model from Amazon for use in the UK and USA and I am concerned I will have issues if it connects to a 4G+ network.
        Can anyone please advise?
