Powerbreed
Sep 19, 2020Follower
Nighthawk M2 Screen won't turn on.
I have i Nighthawk M2 that seems to be working fine but the screen won't turn.
I normally just check the screen to see how much data we have left for the month but it no longer displays the screen.
Blue light and the internet is working, so i guess im just checking if anyone else has had this issue.
- NickamInitiateI have the same issue. It actually takes a long time to get a response. Sometimes i am just so annoyed and i simply remove the battery and restart it again. But i guess it hurts the device. Anyone know how to fix it?
- Blanca_ONETGEAR Employee Retired
Hi Powerbreed and Nickam
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR2100-xxxx)? This can be checked on the box of the product or on the barcode label.
What is the firmware version?
Kindly access router settings page, select Settings > Advanced Settings > Device and provide the following:
- Screen Brightness:
- Screen Lock (is it On or Off)
- Time Out (number of minutes)
- Set WiFi Info on Home (On or Off)
Blanca
Community Team
- SharkM2AspirantYes, have the same problem.
Modem works but screen doesn't work.
Anyone have a solution?- Rygar707InitiateI have the same problem. Unit working but can’t get screen to wake up. Anyone have a fix for this?
Hi, All,
We are looking into the issue. May we request for the following information:
- Device SKU (e.g. MR2100-xxxx)
- Firmware version
- ISP
Blanca
Community Team- Blanca_ONETGEAR Employee Retired
Hi Powerbreed Nickam SharkM2 Rygar707
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
- BellwoodGuide
I'm also experiencing the same thing - the modem has been on continuously for over 2 months, and now the screen is black and doesn't re-appear on pressing the power button (which is blinking blue) or the home button. However it is working perfectly as a modem. I have not yet taken the battery out because, well, it is working, so why risk losing my internet Also, my admin options do not include a "screen off" function, only a brightness control.
Has a solution been provided by Netgear?
Here are the details:
Model: MR 2100
Firmware: NTGX24_10.17.03.00
Modem Version: SDX24_10.25.00.01
GUI Version: MR2100-1TLAUS_04.02.151.00
PRI Version: 03.12
Firmware Build Date 2020/01/09Thanks
Phil
- MCVPAspirant
The LCD screen is not working and I have taken battery out to reboot with no result.
- VdraneAspirantBox won’t stay on or go past netgear logo when turning on when I have a SIM card in it. Any help please. Do I need a new battery? I have it connected to the power supply.
