1PAUL1
Jun 20, 2012Novice
2 vlans GS748T to 2 vlans GS724TP lock nwrk conns
I don’t post too often but just recently bought some new hardware that is not playing well sssooo. Reviewing forum post did not readily find a similar instance. Here are the problems right up front. ...
1PAUL1
Jun 26, 2012Novice
Here is diagram and original 2nd question needing to be answered:
2) How can control be re-established with the GS724TP without reset to factory defaults? Although switch is working; cannot ping, cannot see in Smart Control Center, does not show up in 748T mac address table. PVID 1 changed to PVID 4 and 5 for all ports. PVID1 may have been the mgmt PVID
Gs748t is one switch and GS724tp 2nd switch; connected with 2 fiber GBICs.
Router FVS318v3--|---GS748T VLAN1
| fiberport50-|
| +ports12345 |----Nwk1
| fiberport23
| GS724tp
| VLAN1
| ports12345-----------NWk1
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| Ports6789-------------Nwk2
| VLAN2
| GS724tp
| fiberport24
| fiberport49-|
| +ports16789 |-----Nwk2
|---GS748T VLAN2 |
| fiberport50-|
| fiberport23
| GS724tp
| VLAN1
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| VLAN2
| GS724tp
| fiberport24
| fiberport49-|
|---GS748T VLAN2 |
