Benoit72's avatar
Benoit72
2016 Teaming doesn't work with M4300-52 G
Hello, I try to replace a old Netgear Switch (GS748Tv5) by a M4300-52 G. 2 switches are stacked. I have a Windows 2016 server (vlan 35). The server is connected to the old switch through a teaming (...
  • Benoit72's avatar
    Benoit72
    Mar 15, 2018
    Hello,
    It's Ok now. I forgot the PVID on LAG1 on new switch. I found the solution on this community.
    Thanks.
    Benoît
ProSupport for Business
