Benoit72
Mar 14, 2018Aspirant
2016 Teaming doesn't work with M4300-52 G
Hello, I try to replace a old Netgear Switch (GS748Tv5) by a M4300-52 G. 2 switches are stacked. I have a Windows 2016 server (vlan 35). The server is connected to the old switch through a teaming (...
- Mar 15, 2018
Hello,
It's Ok now. I forgot the PVID on LAG1 on new switch. I found the solution on this community.
Thanks.
Benoît
Retired_Member
Mar 15, 2018Hi Benoit72
Welcome to the community!
Could you please run below CLI command? We want to get more detailed info for analysis this problem.
show port-channel 1
show running-config interface lag 1
Beside, I notice the LAG type is static on old switch(GS748Tv5), so please make sure it's same config on new switch(M4300-52G).
Hope it helps!
EricZ
NETGEAR employee
Benoit72
Mar 15, 2018Aspirant
Hello,
Thanks.
Benoît
