ProofOfLife
Dec 19, 2016Aspirant
Adaptive Load Balancing with GS728TP, is it possible?
I work for a company installing mostly access control, but I recently was given a job to perform using a couple dozen IP cameras, three workstations, and three recording servers. I have two Netgear P...
ProofOfLife
Dec 21, 2016Aspirant
Awesome, thanks!
Unfortunately, I have a new difficulty, which is that I cannot reach the setup page for the switch. I put my laptop in range (192.168.1.10 is what I assigned) but can neither ping the switch, or see it using the Smart Control Center.
Can anyone offer a suggestion for what I might be doing wrong? I have installed SCC on two different laptops, and have same result.
ProofOfLife
Ah, I see that I have been assuming the wrong IP address.
If, after approximately one minute, the switch does not receive an IP address from the DHCP server (or does not find a DHCP server), the switch will turn off DHCP and use the default static IP address of 192.168.0.239.
However, it still doesn't appear in SCC.
