ProofOfLife
Dec 19, 2016Aspirant
Adaptive Load Balancing with GS728TP, is it possible?
I work for a company installing mostly access control, but I recently was given a job to perform using a couple dozen IP cameras, three workstations, and three recording servers. I have two Netgear P...
ProofOfLife
Dec 21, 2016Aspirant
Ah, I see that I have been assuming the wrong IP address.
If, after approximately one minute, the switch does not receive an IP address from the DHCP server (or does not find a DHCP server), the switch will turn off DHCP and use the default static IP address of 192.168.0.239.
However, it still doesn't appear in SCC.
LaurentMa
Dec 21, 2016NETGEAR Expert
Good news if you now can access the switch GUI (web interface). Let us know how it goes.
For SCC, some filtering must happen somewhere, this is not an issue for your load balancing right now.
Please keep an eye on it too -
