港区のNE
Jul 08, 2020Aspirant
Authentication method using MAB
Hi I want to perform 802.1x authentication using MAB. I want to do MAB authentication using the MAC address. Please tell me the setting of the port to connect the target PC. The location will be i...
DaneA
Jul 09, 2020NETGEAR Employee Retired
Welcome to the community! :)
As far as I have checked on page 546-548 of the M4300 user manual here, when you go to Security > Port Authentication > Advanced > Port Authentication on the web-GUI, you may used MAB to either enable or disable MAC-based. The default setting of MAB is Disable.
DaneA
NETGEAR Community Team
港区のNE
Jul 12, 2020Aspirant
Thank you for your reply.
I know the information in the manual, but it doesn't work when set.
I have no problem setting the RADIUS server.
Please let me know if there are other causes.
