PaulBowles
Nov 23, 2017Aspirant
Backup GSM7224 L2
Hi. I have a GSM7224 and wish to backup via a command line as there is no GUI. Does anyone know the said command to backup the current config. I have a TFTP server already i thought something like co...
- Nov 23, 2017
According to the manual, you can use a URL for the destination. For TFTP, that would be tftp://<ipaddr|hostname>|<ip6address|hostname>/<filepath>/<filename>.
For example:
copy nvram:startup-config tftp://192.168.1.1/tftp/config.cfg
TheEther
Nov 23, 2017Guru
For example:
