jlomo
Jun 25, 2016Aspirant
Basic configuration GS110TP for dummies...
Hello,
I put a gs110tp in my network. The goal is to limit one port to internet access only. That port is connected to a wireless access point in an other house for tourists.
I do not want them to see my private network on the other ports.
As I have no idea on how to set this certainly easy configuration I hope somedy will help.
Thank you in advance.
Best regards from Belgium.
Note: I am a beginner in network configuration as you can understand with my question.
Hi jlomo,
Welcome to the community! :)
You will need to configure 2 VLANs. One VLAN for your private network and another VLAN for the tourists network. Kindly read the article below as reference guide:
Multiple VLAN Configuration Between NETGEAR Firewalls and Switches
Does the access point supports VLAN? What is the brand and model of that access point?
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi jlomo,
DaneA
NETGEAR Community Team- jlomoAspirant
Thank you for your prompt reply.
It seems easy to follow your guide.
The access point I am using is a Linksys WAP300N, but I also have a Netgear WPN802 v2. I think none of them are vlan compatible !
After having checked for other possible solutions I found a more professional approach using a hot spot from Intellinet, model GuestGate MKII. Before buying a Vlan compatible access point I will test the hot spot.
Thank you again and best regards.
