swu5966's avatar
swu5966
Basic VLAN/Routing Config GSM7224
Hello All,
My background has been more in the HP Procurve world and I am in a Netgear environment and looking for some basic configuration help to get me rolling.
I have GSM7224 and GS748T switches. I would like the FSM7224 to be the default gateway and handle the inter-vlan routing, which is currently being handled by the firewall. I am introducing a few more VLANs to clean things up. Here's what I would like to do:
VLAN 1 - MGMNT        10.10.1.0
VLAN 10 - IP Phones   10.10.10.0
VLAN 20 - LAN A          10.10.20.0
VLAN 30 - LAN B         10.10.30.0
VLAN 40 - WIFI            10.10.40.0
VLAN 50 - Servers        10.10.50.0
Internet (FW)               172.17.10.1
For all of the VLANs, the .1 gateway interface is on the GSM, the all zero's route points to the Firewall, on 172.17.10.1.
If anyone can provide some basic config tips, examples, or suggestions, that would be much appreciated!  Thanks in advance!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi swu5966,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your concern or if you need further assistance.  If ever your concern has been resolved, we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
