MichaeleBlack
Nov 30, 2015Aspirant
bidirectional wavelength SFP module M4100-12GF
I am looking for a bidirectional wavelength SFP module that is compatible with the M4100-12GF
- JohnRoNETGEAR Employee Retired
Hello MichaeleBlack,
Welcome to the community!
We have only three SFP models that are guaranteed to work with the M4100 series (AFM735, AGM731F and AGM732F). I have seen some brands claim to have also been compatible like Add-On and Extreme Networks', I believe as long as they have the same standards they should work. Still, I would suggested the out SFP modules over the others.
I hope this helps, let us know.
Thanks,
- MichaeleBlackAspirant
Thanks - my problem is that I have only one single mode fiber strand available from the MDF out to 6 different locations, so I need a BIDI SFP to accomplish this connection. My plan is to use the M4100-12GF at the MDF and GS110TP at each of the six IDF locations using the BIDI SFPs for connection.
- msiLuminary
The M4100 and other fully managed switches from Netgear so far have been very tolerant on SFP(+) compatibility for what I can tell. I've used various unbranded and other-vendor-branded modules in them without any issues. This allows actually installing modules a switch vendor might not offer you such as different wavelengths or BiDi as you need.
I'd recommend you to get a pair of unbranded (plain MSA standard) BiDi optics and test them out, the gigabit ones aren't very expensive these days.
I've had quite some success with optics from a certain Germany-based company and so does a local ISP here who extensively uses their BiDi optics as well.
Fine print: Remember that in some cases the vendor (in this case Netgear) can ask you to swap third-party optics first if you run into issues before they help you.
